#26 | |
If I need to weld on new brackets on the rear end, would I be getting rid of my trailing arms? What would I do? Shave all of the old mounts off my rear end and weld on new ones? The 4-link would replace the trailing arms and the new brackets would be for the bags? Is this at the point when someone might decide to switch to a 9"? I don't want to steal anyone's thread here.... Does anyone have any other pictures of a bare frame with air ride installed? Thanks for everyone's help.
Baby Blue's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=652776 Project 68's Build Thread: http://67-72chevytrucks.com/vboard/s...17#post8442117 www.stonecolumnclassics.com Email: Josh@stonecolumnclassics.com |
#27 |
Progress = 0%
Check out my web site. It shows pics of my air ride system. A 9" has nothing to do with air suspension, it's just a personal preference. You don't need a 4-link either.
jayspot.com
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
#28 |
www.loweredd.com
I wondered about the 9" part of your post too. Stock floor body drop is a little bit different than channeling. With a stock floor body drop, you remove the offending (lowest part of the frame) piece of frame, to make it even with the rocker panels. Then it lays on the body, not the frame.
#29 |
www.loweredd.com
here's a pic (hopefully)
#30 |
loweredd...Cool truck! Thanks for the pic.
Slammed67...Your website is awesome. I've checked it out before. Definately some good pictures on there. Do you have the floor back in your truck? As far as my comments go about a 9" rear, that's what we use in our street rods and I know I can get parts cheaper for them. I was just thinking that if I had to weld a bunch of new brackets on my rear end, I might just start with a new rear considering mine probably needs freshened up and some kind of limited slip installed. Thanks for everyone's help. I'll be deciding soon what to do. Bags sound more complicated than what I want to deal with. Perhaps I'd be better off with a set of dropped spindles and dropped springs. Might be quicker although the adjustability of ride height sure is appealing.
#31 | |
www.loweredd.com
Makes sense about the 9 though. Might as well start out with a new axle tube to weld to! ![]() |
#32 |
Uuhhmmm, I've always been under the impression that stock floor bodydrops were lowering the body in relation to the frame.... as in removing material from the top of the frame, not the bottom.
If you remove material from the bottom of the frame, it will allow you to plant the rockers flush w/the frame rails but only @ a very compressed ride height. But.... removing the material from the top of the frame (and relocating the cab/body mounts) lowers the body (truck) while leaving the suspension (and ride) unchanged. The 'stock floor' part is just doing the drop w/o altering the floor pan of the truck/vehicle. A regular 'body drop' raises the floorpan for clearance & 'channeling' notches the floorpan for the higher frame-rail location only. Someone correct me if I'm wrong.....
#33 |
www.loweredd.com
On an S-10 Scoti the first stock floor description is correct. On these trucks, the only part that hangs down is right under the cab, and that is what gets chopped off.
*edit* Have you ever seen a truck with any body drop that was not on airbags? Last edited by loweredd; 08-19-2003 at 11:53 AM. |
#34 | |
Trucker.
#35 | |
www.loweredd.com
#36 | |
Trucker.
#37 |
www.loweredd.com
uh-uh, it's a LWB....the frame is down about 2 inches lower than the cab.
#38 | |
Trucker.
Learn something neve everyday. ![]() |
#39 |
www.loweredd.com
a SWB is thast much different? I wonder why? Yeah, the front crossmember is WAY low, and the tranny cross and the tank actually is a little low too. BUT....then it still does have the frame. Within an inch blows though, LOL. I might even get rid of the pinch weld! Then I really need to lose some frame.
I dont want anyone to think I'm not agreeing with them (scoti). I suppose a stock floor could be anyway you wanted to do it. |
#40 |
www.loweredd.com
This is an S-10...but.....you could do a stock floor body drop this way.... It's still a body drop, and still a stock floor.
#41 |
No probs here....
Since I've got both the 67-72 model as well as a 73-up I've crawled under both to see what it takes to get them low & still be drivable. I'm not against planting the rockers on the pavement by airing out the suspension.... but for me, I like driving them low & still maintaining suspension travel, so it is for this reason I would remove material from the top of the frame before the bottom. Weird thing is.... as close as the suspensions are between these year trucks (67-74) that I have, the 74 has less fenderwell area that the 67/8 does & although my 68 is actually lower than my 74, the 74 bottoms out much easier when going down the road. Both were dropped up front using the same methods/materials so there shouldn't be much difference & both of them are relatively flush as far as frame-rails vs. cab/rockers. I actually measured the difference on my 67swb in the garage & it was less than 3/4" & not worth the hassle of doing a body drop.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 08-19-2003 at 05:25 PM. |
#42 |
Just another way to Stock Floor Body Drop one of our trucks- To put a peice of 2x4 square tubing along the frame rails. Weld it in there then cut off the top of the old frame and move down thecab mounts, there you have a stock floor body drop. There are a few other thing to do like cut off the horns and drop them down too. If you have a SWB- you should be able to to lay body with out body dropping it! Here is my partners 54 chevy. Its body dropped alot and is NOT on air.
#43 |
Signals in the bumper.
Man that stepside looks good! As soon as we get our garage built, I am dropping mine. I want to do some more serious cutting.
Jeff C. 1981 Chevrolet Silverado - Under major construction...again. link 1962 Chevrolet Impala 4D Sedan moredoorclassics.com 1936 Ford Pickup - Frame-off in progress link 1979 Chevrolet Camper Special Flatbed link |
#44 |
www.loweredd.com
That stepside is done by SilverStarCustoms.
#45 | |
Trucker.
#46 | |
Trucker.
#47 | |
www.loweredd.com
#48 | |
Trucker.
#49 |
www.loweredd.com
really? I've seen a few of thier cover trucks, and they look great! They just got done with one of my buddies truck, and the rear suspension is killer!
#50 |
www.loweredd.com
here's the truck,
