Old 10-17-2011, 10:00 AM   #26
dfwright
dfwright's Avatar
Re: Serpentine Conversion Help
subscribing
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 10-10-2017, 11:16 AM   #27
novice
I know this is an old thread but I'm wanting to install a serpentine set on my 454. Will the vintage air compressor work with this setup?
novice is offline   Reply With Quote
Old 10-10-2017, 09:44 PM   #28
TCCGRIZ
Subd
TCCGRIZ is offline   Reply With Quote
Old 10-10-2017, 10:16 PM   #29
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
What compressor are you using? R4 or Sanden?
I can take some more pics of my set up if you want. I think the only issues would be if you used tall valve covers.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 10-11-2017, 06:42 AM   #30
novice
Smitty
I'm not 100% sure which comes with the Vintage air kit. I've read that the R4 unit is not a preferred choice. Is that so?
Old 10-11-2017, 08:39 PM   #31
71meangreenc10
From my experience that is correct.
Smitty
71 C30 Wrecker
Old 10-11-2017, 08:45 PM   #32
lilpanther
I don't know what the linking rules are on here but if you search for "AS-SANDEN-R4-KIT" it adapts a sanden compressor to the r4 bracket.
lilpanther is offline   Reply With Quote
Old 10-02-2021, 02:37 PM   #33
4thgencreamsicle
I didnt drill in my head for one bolt, but I have the bracket that bolted to the water pump, so everything is pretty strong.
Smitty
Ok, so we’re doing this conversion right now and trying to find a bracket because we’re not gonna drill the head. I know this was a long time ago, but do you remember where you got that bracket coming off the water pump?
4thgencreamsicle is offline   Reply With Quote
Old 10-02-2021, 08:33 PM   #34
Peanut74
I called Vintage Air when I added A/C to an early 350 that I put a 80's era serpentine system on. They said no problem sent me the parts. They sent some adapter brackets to convert my serpentine setup from an R4 to Sanden.
So in short its worth a call and talk with them directly. I'm sure you are not the first one to do this with one of their kits.
1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion)
1989 Toyota DLX pickup "The Hulk"
Peanut74 is offline   Reply With Quote
Old 10-02-2021, 08:57 PM   #35
71meangreenc10
Are you referring to the support rod?
Smitty
71 C30 Wrecker
Old 10-03-2021, 07:17 PM   #36
4thgencreamsicle
Smitty
Yep, that one that’s going over to the water pump bolt.
Old 10-03-2021, 08:47 PM   #37
71meangreenc10
Mine came with the set up. I pulled it off a 4.3.
Smitty
71 C30 Wrecker
