Old 10-18-2011, 10:14 AM   #1
HeavyMetalChevy
Just a Member
HeavyMetalChevy's Avatar
Complete BIG BLOCK rolling body and frame 71 Custom Deluxe Part out
This truck was the RARE 402 BIG BLOCK setupWood Longbed. I will have any detailed pics and prices you need but here come many...This has all the added suspension options I believe.. it had the bb 402 in it!!! Someone got to it before I did...Thanks...Duane. I am goig out to start pulling parts... be back after a while...Stay tuned
bed-SOLD LOCAL pend. payment
4 core Rad support with AC-$150 Solid
2 piece shaft with carrier bearing-$50
Mirrors Nice-$50 shipped
TH400 crossmember-$50
Front Sway-$60 with frame brackets
Fenders-$75 driver $100 pass pass sold to 72KSzl1
BB Heat shield and engine stands-$175 shipped Engine Stands $100 ship... heat shield $100 ship
Set spoke rims-$200 set $300 with tires Goodyear Wranglers with 1/8" tread until wear indicator
Disk Brake Booster- 80 shipped sold to zombiefied
Hood-$150 Completely Solid SOLD LOCAL
Rear Bumper with Hitch option and brackets-$225... Rear Bumper- $125... Rear Bumper Brkts-$70... Factory Hitch-$70 All sold pending local payment
Front Disk Entire Setup- $300
Outer AC box-$50
Inner Ac/Heat Duct and Heat Core housing-$60
Rear Slider- $40
Bench Seat nice springs-$50
Cab Mounts-$75 set...$20 a piece
Inside Bed Rails Sides- NOT ONE DING- $200/pc $350/both
Front Gate- NOT ONE DING-$150
Driver inner fender-$50
Pass Inner Fender-Junk
Rear End Dana 60 Open-$200
Rear Suspension Leaf and Spring Heavy Duty RPO-$150
Rear Drums and Brake Setup-$75
Cowl Panel Outer $40 shipped CONUS sold to jessewebb when picked up
Complete Wiring Harness with ignition and key $150 shipped CONUS tested and worked (fuse box,volt reg, front pigtails for markers and all lights,alt, EVERYHING!!!) sold to zombiefied
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st)
69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd)
70 C-20 88 350 long block rebuild .040 bore. forged crank
GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum
TH400(3rd)
71 SWB frame off with 68 body. POSI
PayPal: remimartin257@aol.com
Business Inquires: 812 801 5111
"Help me, help you" that's my motto
Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog
Last edited by HeavyMetalChevy; 11-04-2011 at 01:46 AM. Reason: prices and sale updates
HeavyMetalChevy is offline   Reply With Quote
Old 10-18-2011, 10:17 AM   #2
HeavyMetalChevy
Just a Member
Re: Complete rolling body and frame 71 Custom Deluxe Part out
More
TH400(3rd)
Old 10-18-2011, 10:18 AM   #3
HeavyMetalChevy
Just a Member
more... 2nd picture here features FAACTORY OE HITCH!!!! BAD MOTHA'
TH400(3rd)
Old 10-18-2011, 10:19 AM   #4
Levi.Johnson
Levi.Johnson's Avatar
What kind of shape is the lower trim molding in on the driver's side? And how much for all?
Levi.Johnson is offline   Reply With Quote
Old 10-18-2011, 10:21 AM   #5
HeavyMetalChevy
Just a Member
going to get pics now Levi...gimme a sec
TH400(3rd)
Old 10-18-2011, 10:28 AM   #6
hatred
hatred's Avatar
How much for the a/c switch and cabled, and the complete horn parts in/under the steering wheel?
Tony
05 QSM GTO - M6, Corsa, King Springs
70 SWB CST - 350/Auto, Foose 18/17
I upset whiners too....
hatred is offline   Reply With Quote
Old 10-18-2011, 10:35 AM   #7
HeavyMetalChevy
Just a Member
pics for Levi...
TH400(3rd)
Old 10-18-2011, 10:36 AM   #8
HeavyMetalChevy
Just a Member
last driver side trim pics
TH400(3rd)
Old 10-18-2011, 11:02 AM   #9
daddymoo2
Smile Re: Complete rolling body and frame 71 Custom Deluxe Part out
any pics of inside dog house or core support. Thanks
daddymoo2 is offline   Reply With Quote
Old 10-18-2011, 11:05 AM   #10
HeavyMetalChevy
Just a Member
Coming right up....Finally got her here!!!!! YEahh buddy!
TH400(3rd)
Old 10-18-2011, 12:10 PM   #11
HeavyMetalChevy
Just a Member
daddymoo...core support pics and doghouse....
TH400(3rd)
Old 10-18-2011, 12:12 PM   #12
HeavyMetalChevy
Just a Member
more
TH400(3rd)
Old 10-18-2011, 12:14 PM   #13
HeavyMetalChevy
Just a Member
Tony
hatred I am not 100% sure what you are wanting... Please specify...The controls or switch.. where located/
Thanks,
Duane
TH400(3rd)
Old 10-18-2011, 12:17 PM   #14
daddymoo2
How much for power steering pump assy. Thanks Daddymoo2
Old 10-18-2011, 12:25 PM   #15
too much stuff
Roadtrip!
too much stuff's Avatar
How much on the engine stands and heat shield on pass firewall?
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 10-18-2011, 01:33 PM   #16
hatred
hatred's Avatar
Thanks,
Duane
The horn pieces under the horn button and under the actual steering wheel. Little plastic parts, springs, flat metal disc and things...
Old 10-18-2011, 01:58 PM   #17
Levi.Johnson
Trim is rough, but still interested depending on price (for both sides).
Thanks,
Levi
Old 10-18-2011, 01:58 PM   #18
jstevens
How much for the.custom delux embpems shipped to 26431?
jstevens is offline   Reply With Quote
Old 10-18-2011, 02:22 PM   #19
webfoot
How much for the lighter element only (no socket or bezel needed) and the wire that runs off the back to the fuse box? 97838
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 10-18-2011, 03:03 PM   #20
coops714x4
coops714x4's Avatar
how much for the outer grill shipped to 73018, Thanks Coop
1971 K20, Coop's beast (project)
1972 C30 wrecker, "Big Ernest" (SOLD)
1975 K5 Blazer (wife's toy) she got it in the divorce
2014 Street Glide Special
1983 K20 Big Block, auto (work horse)
coops714x4 is offline   Reply With Quote
Old 10-18-2011, 03:45 PM   #21
HeavyMetalChevy
Just a Member
I will prob have to get around 100 for the engine stands they are rare and hard to come by...I am sure you know that as well... They will be heavily degreased though as all my parts... And I can even strip/blast for you if need be... I will have to check on the pass firewall shield...
Let me know,
Much Appreciated
TH400(3rd)
Old 10-18-2011, 03:47 PM   #22
HeavyMetalChevy
Just a Member
Coop...I really dont want to separate the grille but if need be I will... There is a small ding on the pass side if you did not notice...Also I want to have it repaired first or is that what you plan on doing??? Let me know and I will give price.. Like I said though...Would rather sell whole...
TH400(3rd)
Old 10-18-2011, 03:49 PM   #23
HeavyMetalChevy
Just a Member
The pass side deluxe part of emblem has one post missing... Other than that the Custom emblems are both excellent... The Deluxe shows some pitting but still all chrome... 50 bucks shipped???
TH400(3rd)
Old 10-18-2011, 03:52 PM   #24
HeavyMetalChevy
Just a Member
Thanks,
Levi
The pass. side is ALOT better shape.. pics coming...
TH400(3rd)
Old 10-18-2011, 04:22 PM   #25
coops714x4
coops714x4's Avatar
Ok how much for the whole thing Ill do the repair shipped to 73018
