Old 10-18-2011, 02:46 PM   #1
BENC-10
Inner Rockers
Need advice on installing my inner rockers.. is this how they are supposed to go?
BENC-10 is offline   Reply With Quote
Old 10-18-2011, 07:59 PM   #2
JimKshortstep4x4
Re: Inner Rockers
Are the inner rockers long enough to bolt up the the pillar posts? I have always tried bolting them onto the pillar posts.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 10-19-2011, 06:22 AM   #3
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Re: Inner Rockers
Looks right to me. Your outer rocker will sit on that notched lip. Looks like you need a front pillar patch too. If you don't have one, they are cheap and available. Then you can bolt it at that location as Jim mentioned. Will be strong like bull.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 10-19-2011, 10:53 AM   #4
Lippyp
English Chevy Owner
Lippyp's Avatar
Re: Inner Rockers
Heres some shots from when I did mine. I didn't use the whole thing as the back end was still good so I cut it down a bit. In the first shot the end is bolted to the frame outrigger (cab support) , it was then plug welded to it and the bolts for the A post bolted through it.
new lower kick panel in place
new lower door pillar repair in place
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 10-19-2011, 11:59 AM   #5
BENC-10
Re: Inner Rockers
Awesome! thanks lippyp..ill get to it this morning..So the new inner rocker has to match up w/ the holes on the cab support?
Old 10-19-2011, 12:09 PM   #6
BENC-10
Re: Inner Rockers
Ohh. i just remembered something else should i patch this before i do the inner rockers?
Old 10-19-2011, 12:48 PM   #7
treveiger
treveiger's Avatar
Re: Inner Rockers
I've heard to work from the inside out when doing rust repair.
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 10-19-2011, 01:40 PM   #8
BENC-10
Re: Inner Rockers
I see..would i have to cut out a piece of kick panel to patch the floor?
