10-20-2011, 07:53 PM | #76 |
Who's got steelies?
Re: An expensive lesson learned
Thank you. Based on what a lot are saying in this thread, all of my rides should have had wiped cams 5 or 6 years ago. For several years, before I rebuilt my truck's engine, I used the cheap Q-state oil, and it was lucky if I changed that oil every 10,000 miles! It had 212,000 miles on it and still ran down the road when I pulled it. I don't use Q-state any more and change oil every 3,000 miles, but I don't worry about ZDDP, and they still work. I don't have any non-stock, aggressive cams either.
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
10-20-2011, 08:33 PM | #77 | |
Still Learning
10-20-2011, 08:40 PM | #78 |
Second Chance Program
Subscribed for the good info.
10-20-2011, 11:40 PM | #79 | |
10-21-2011, 12:40 AM | #80 | |
http://www.amsoil.com/storefront/amo.aspx Posted via Mobile Device
1969 Chevy c20(Miss Hackjob) |
10-21-2011, 07:51 AM | #81 | |
again good luck.. the need for the zinc isn't some ole wifes tail.. and some of this bad info, like say'n amsol is fine, is why new engines are failing within 5-10k after break in.. my engines have to much money in them to "chance it" anything under 1200ppm is not enough and it's not just the cams and lifters it's the valve stems and rocker tips and balls. (non roller) any part that slides. new engines don't have these issues, as most are ohc and the hold out ls is roller |
10-21-2011, 08:16 AM | #82 |
oops just figured out it isnt a connectingrod but a pushrod , did you check the clearance on the springwindings at full lift , it could allso be if you have hydraulic lifters that the one with the bend pushrod pumps up a but under stress check the return oilhole inside the lifterbore and if theres a hole in a different place compared to the other lifters or holes you can allso check the oilseal on top of the valveguide to see if by any chance the thingy holding the spring to the valvestem hit it ..... that should be eaziest to check first right after checking the windings at full lift allso check if the rocker is hitting the valve straight on , basicly anything that can cause binding
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
10-21-2011, 07:44 PM | #83 | |
10-22-2011, 02:39 AM | #84 | |
To say that its ams oils fault that cars blow up is a sad remark. My bro in law runs it in his corolla since brand new an has the oil tested regularly an NO PROBLEMS of wear what so ever. It won't protect driver stupidity, no oil can. I've seen proof that ams oil works an others don't compare... Sorry truth hurts sometimes. Posted via Mobile Device
10-22-2011, 07:34 AM | #85 | |
10-22-2011, 08:25 AM | #86 |
Big difference between a Corolla and our trucks.
2006 Silverado CCSB, 1939 Ford Sedan, 1962 BelAir Wagon, 1976 Vega Panel Charleston, South Carolina |
10-22-2011, 01:33 PM | #87 |
Moderator
I think this thread has now just about run it's course...
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
