Old 10-20-2011, 08:04 PM   #1
Rogue_Alphonse
Rogue_Alphonse's Avatar
Hook up a tach to a 6.2
Don't feel like researching. It's one of those little Sunpro tachs I took from my Blazer because I converted to a tach-in cluster [that I made using the same kind of Sunpro tach]
1991 Mustang GT Vert, T-5 w/ Pro 5.0, Trick Flow upper & lower, BBK cold air intake, 3:73, BAMA chip, etc.
1988 K5 Blazer, [coming soon] TBI 400, SM465/NP208, 12 bolt rear, 3:08's, looks like a 1980.
1998 Jeep Grand Cherokee 4.0 fully loaded daily driver!
Where there's a will, there's a rig!
Rogue_Alphonse is offline   Reply With Quote
Old 10-20-2011, 10:04 PM   #2
rcbildr
rcbildr's Avatar
Re: Hook up a tach to a 6.2
It's been a while since I researched it, but I think to hook up a tac on a diesel is pretty spendy. IIRC there are 2 ways to do it...mechanically off the vacuum pump or electrically off the alternator. I can't remember what exactly is involved trying to hook it up mechanically I just vaguely remember it has to do with the pump. Electrically, there is a gizwidget you can buy that attaches to the alternator.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 10-20-2011, 10:36 PM   #3
rustyrodknocker
I think you can just put a hall effect sensor or maybe even a magnetic pickup on the balancer they use them to read rpm on any thing that spins. Ive seen something of the sort adapted to old machining equiptment.
rustyrodknocker is offline   Reply With Quote
Old 10-20-2011, 10:38 PM   #4
rustyrodknocker
this would be for a digital read out of course
Old 10-20-2011, 10:56 PM   #5
arrover
arrover's Avatar
I'm far from an expert but I have read quite a bit on it. You should search in the 6.2 section of dieselplace.com : http://www.dieselplace.com/forum/forumdisplay.php?f=20
Here is one way: http://www.dakotadigital.com/index.c...128/prd128.htm
Another: http://www.dakotadigital.com/index.c...rod/prd129.htm
Autometer makes a medium size tach that has a strap that goes around the alternator to get a signal. They also make a 5" diesel tach that comes with the sensor that reads from the ballancer etc.
Tinytach makes a digital tach but I don't think its round like a normal tach.
arrover is offline   Reply With Quote
Old 10-21-2011, 12:07 AM   #6
Rogue_Alphonse
Wow I never knew it was this much of a PITA.
Old 10-21-2011, 08:58 AM   #7
lindstromjd
Gentleman Jim owner x2
lindstromjd's Avatar
It's because of the lack of electrical output to make the engine run. I made a hybrid sender out of my vacuum pump and an HEI distributor like on dieselplace.com, but they're tricky and take a good day's worth of work to get it done.
1975 GMC Gentleman Jim #1
-357 / 700r4
1975 GMC Gentleman Jim #2
-350 / TH350
lindstromjd is offline   Reply With Quote
