Old 10-24-2011, 01:41 PM   #1
lenguini
lenguini's Avatar
Want to use a smaller power brake booster
Greetings all,wanting to use a smaller diameter brake booster/master combo in my 65 c10build.
Using an 81 half ton disc front end with its matching calipers, 10" brake booster,master cylinder and proportioning valve. At the back using a 1972 307 rearend with drums.
What do I need to get there ?
All help with a solution will be much appreciated.
Thankyou in advance.
lenguini is offline   Reply With Quote
Old 10-24-2011, 04:04 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Want to use a smaller power brake booster
If it’s in your budget, Master Power Brakes offers both a 9” booster and an 8” dual diaphragm booster. I’m running the 9” and it works fine, but the 8” would generate even more power if you prefer a softer pedal. While the 8” is smaller around, it also takes up a lot more space lengthwise.
http://www.mpbrakes.com/products/pro...product_id=194
http://www.mpbrakes.com/products/pro...product_id=631
Old 10-24-2011, 06:19 PM   #3
gimmy 64
i used the stock booster that came with my 64 gmc. you can still get them from autozone or else where.
gimmy 64 is offline   Reply With Quote
Old 10-24-2011, 08:19 PM   #4
lenguini
lenguini's Avatar
Today I have Been looking at a 7"dual diaphram booster from speedway,whats your thought ?
Old 10-24-2011, 08:33 PM   #5
64shortbox
64shortbox's Avatar
Smile Re: Want to use a smaller power brake booster
Personally I like Speedway, good prices. You also might be able to use a dual diaphragm booster from a Chevy mini van I think thay are 9" but the mounting studs are metric and you would need to run a 3/8" - 24 die down the pushrod of the booster. The Speedway unit would be a direct bolt in.
Don't forget about these:
They would make your life a LOT easier:
http://www.speedwaymotors.com/Univer...Heim,9329.html
http://www.speedwaymotors.com/Remova...ose,45896.html
http://www.speedwaymotors.com/GM-Cor...ore,51673.html
What can I say - I'm cheap and lazy.
64shortbox is offline   Reply With Quote
Old 10-24-2011, 10:12 PM   #6
samuellg1977
samuellg1977's Avatar
Lenguini,
I hope you don't mind, but i think this crew may be able to help me also. My Q: Why does my brake booster make a loud "sucking" sound until I press the brake pedal? Thanks. Sorry, I didn't mean to hijack the thread.
samuellg1977 is offline   Reply With Quote
Old 10-25-2011, 01:01 AM   #7
Captainfab
60-66 Nut
Member towersddg9 just posted a couple pics of his CPP booster and master combo, mounted with my booster bracket here......
http://www.67-72chevytrucks.com/vboa...80#post4971880
I don't know what diameter the booster is though....looks pretty small.
Old 10-25-2011, 09:51 AM   #8
lenguini
lenguini's Avatar
Thanks for the pics Cap,appreciate it.
Ed.
Old 10-25-2011, 10:02 AM   #9
summerj
What is the pupose of the booster Bracket that goes between the firewall and the booster? Is it a neccessity?
summerj is offline   Reply With Quote
Old 10-25-2011, 12:20 PM   #10
HEI451
That bracket bolts to the firewall, and the booster bolts to it, as the stock firewall doesn't have a hole/bolt pattern to mount the booster directly to the firewall. Also makes it so you can mount the booster without hacking/cutting/drilling the firewall.
HEI451 is offline   Reply With Quote
Old 10-25-2011, 12:53 PM   #11
64shortbox
64shortbox's Avatar
Yes that bracket is necessary. All of Captainfab's items are top notch. I bought his power brake booster bracket and it is a perfect fit, it comes notched to clear the steering column bracket. It actually looks even nicer in person than it does in his pictures. I spent the extra and bought his powder coated upgrade. An absolute beautiful piece.
I used Captainfab's Power Brake Booster bracket
Booster is from a 92 Full size Chevy truck (I threaded the push rod 3/8 - 24)
Vacuum check valve & molded hose came from a mid 70's Dodge full size truck
Manifold vacuum T came from an 80's Ford Ranger 4 cyl (I needed multi ports)
Master is from a 67 Caddy (I split the system front to back but still haven't done the Disc brake up grade but I'm working on it)
Old 10-26-2011, 12:21 AM   #12
Captainfab
60-66 Nut
Thanks for the compliment and the pics 64shortbox, and also to HEI451 for the explination
Old 10-26-2011, 07:40 PM   #13
Harley1650
1963 C-10 BBC/Muncie 4 spd
Harley1650's Avatar
I use a 7" dual diapraphm booster with a big block. Works great
Harley1650 is offline   Reply With Quote
Old 10-26-2011, 07:58 PM   #14
66farmer
66farmer's Avatar
Harley what buster did you use and do you have a cam in that BBC I'm asking because I have a big block with low vacume cam.
66farmer is offline   Reply With Quote
Old 10-26-2011, 08:15 PM   #15
mbgmike
We have the 8Inch dual diaphrams on closeout for 45.00 each plus shipping. first come first serve
mbgmike is offline   Reply With Quote
Old 10-26-2011, 09:46 PM   #16
RoyL
RoyL's Avatar
don't see these on your website, all gone?
1965 Suburban
Waiting on Time and Money
RoyL is offline   Reply With Quote
Old 10-26-2011, 10:08 PM   #17
mbgmike
nope. we have over 30 in stock. thanks I checked the website and your right they aren't there. I will add them. here is pic. Can't beat the price.
Old 10-27-2011, 09:32 AM   #18
Harley1650
Harley1650's Avatar
Farmer, My 454 has a little cam but not much so vaccum isnt an issue. When I was checking into the brakes I figured out 8" would work fine with the tall valve covers. I bought a booster, master cylinder, bracket and proportioning valve in a "kit" for @ $225. MbgMike sounds like a great deal if thats all you need
Old 10-27-2011, 01:40 PM   #19
RoyL
RoyL's Avatar
would like one, but still can't find them . . . Under 8" boosters, shows 0 items?? provide a link via PM if you can't here.
1965 Suburban
Old 10-27-2011, 06:43 PM   #20
mbgmike
I have not added them yet. I will do that. this is a sale so the price is just a temporary price. It was supposed to be for forum members only.check back
Old 10-27-2011, 07:05 PM   #21
RustyDan
RustyDan's Avatar
Hey Dudes.
I may be out of step here...but I need a little help.
My '72 developed a vac leak at the rear of the brake booster, has the big hose from the back of my carb feeding only that. I Was getting decent(?) mileage untill this happened.
My Question is likely moot, But I'm gotta try anyway...
"Are the Brake Boosters rebuildable"? or am I chokin on hydocarbo's and it's "replacement only". I have rebuilt just about everything else already so what the hey? Thats why we love em so much ... Right? let me know what you think
"Do not follow where the path may lead.
Go instead where there is no path and leave a trail."
"SEMPER FI"
Never retired-Always a Marine
'72 C10 Longhorn-very daily
'86 C10 Van (mothballed)
previous; '65 C10 shorty
& bunches of M/C's
RustyDan is offline   Reply With Quote
Old 10-27-2011, 07:26 PM   #22
mbgmike
HERE IS LINK TO PURCHASE
http://www.mcssl.com/store/mikesbump...tegory/5072345
THERE IS A 12.00 SHIPPING CHARGE
Old 10-28-2011, 08:41 AM   #23
mbgmike
Originally Posted by RustyDan View Post
Hey Dudes.
While the booster are rebuildable you need to have the correct tools to dismantle them. Cheaper just to replace unless you want to invest the money for tools
