Old 10-24-2011, 06:56 PM   #1
ChumBucket
Sandblaster Hurt Me Bad Today...
Sooo I'm doing my first large-scale (to me) mechanical endeavor, a frame-off '69 restoration; bed, cab, motor/tranny removed, LWB already cut down to SWB and welded back together.
So today was sandblast the frame and misc parts day....got 4 boxes of cool stuff from Nate at Porterbuilt over in the corner starting at me.
Today was the first time I've ever attempted this job, and it will be the last. What an enormous PAIN IN THE A$$!! Using a Westwood blaster, lots of air pressure, perfect weather here in mid-TN...but I got 8 bags of the wrong size Black Diamond and thus the dam nozzle kept plugging up.
So after a 1.5 hour round trip BACK to TSC to swap the stuff out I finally got started only to discover that sandblasting is a $hitty job I wouldn't wish on my worst enemy.
Results look great but wow, I think I'll write a check next time.
ChumBucket is offline   Reply With Quote
Old 10-24-2011, 07:05 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Sandblaster Hurt Me Bad Today...
Sandblasting is not for the faint of heart.It does a great job of cleaning stuff up tho.I hope you get it covered with something so it doesn't flash rust.Just think,now you get to start putting it back together.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-24-2011, 07:06 PM   #3
webfoot
I agree it sucks, but having the right gear can help a bunch too. Also knowing how to hold the gun to make the angle you are blasting at keep a lot of the crap from blowing back in your face. A set of thicker rubber gloves is a must! Also if you are trying to blast through greasy or thick undercoating the media doesn't remove this very efficiently.
My last big job I got 3 bags of 70 grit and all were contaminated with larger chunks of sand. This caused the nozzle to get plugged up frequently and it was very frustrating. Ended up buying a strainer and dumping all the sand through this. I could not believe the amount of large pieces being filtered out. This was Lane Mt stuff I have used many times in the past with zero problems.
Here I am doing the frame of my 68 goat in the backyard.
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 10-24-2011, 07:06 PM   #4
68gmsee
Active Member
68gmsee's Avatar
Yeah, it's dusty and dirty and it's best to wear a sandblasting respirator if doing a big job. I've done small sandblasting jobs using a regular dust mask and even then it was a pain with all the dust flying around. The worst part is the silica which can cause lung damage if breathed in.
68gmsee is offline   Reply With Quote
Old 10-24-2011, 10:09 PM   #5
mbgmike
How did it hurt you?
Welcome to the world of restoration
mbgmike is offline   Reply With Quote
Old 10-24-2011, 10:25 PM   #6
no moa
no moa's Avatar
I have a full heavy hood, and I use a paint resporator and only do one bag a week. Any more than that and it's a huge pain in the butt. But I love the results. So much better than using a grinder and wire wheel.
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently.
http://67-72chevytrucks.com/vboard/s...d.php?t=451950
1971 c10 step 250 3 OTT
1969 c30 TOW-MATER. 307 4 speed, holmes 440 body.
http://67-72chevytrucks.com/vboard/s...d.php?t=451082
2006 CTS-V LS2 6spd.
no moa is offline   Reply With Quote
Old 10-24-2011, 10:26 PM   #7
ChumBucket
You know the deal...nothing is easy.
I'm doing my resto at a buddy's shop, so my time is limited and I want to maximize my time while I'm there by getting my "to-do list of the day" knocked out, so when I start off stalled cause the stupid abrasive was too big it kinda threw my schedule off. NOT TO MENTION the fact that with my "I can make it work attitude" I tried to make big stuff go through a small hole about 10 times before I was banging my head.
Also, I found that blasting, which makes a nice finished product isn't fun. Some parts of the build are hard labor but fun, some are easy labor and suck, and this one just sucked. You know, cutting the frame and re-welding was cool, taking the thing apart was cool, this was the most un-fun/un-cool thing I've done since...well it sucked.
However, at the end of the day, as I was driving home, I was cool with the process because the next time I get to work on the truck I'll putting stuff on....porterbuilt front and rear stuff, air bags, notch, new rotors, etc.
Old 10-24-2011, 10:47 PM   #8
msgross
msgross's Avatar
best bet is to find an industrial trailer shop that does blasting... I did my frame and it took me about three days to do it all... major PITA as you stated...
I took them my axles, springs and few other parts...picked them up a few days later for a few hundred and had zero hassle...
took them my cab, tailgate, bed crossills and a few hundred more... too easy.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 10-24-2011, 11:03 PM   #9
Ackattack
Ackattack's Avatar
yeah, I sand blasted my whole frame. After doing that (and going through multiple bags of sand, buying the blaster, clothing, living in hell, bla bla bla, I will gladly pay someone to do it for me the next go around.
Ackattack is offline   Reply With Quote
Old 10-25-2011, 12:00 AM   #10
AirSpeed
AirSpeed's Avatar
I always liked sandblasting! I think it's kinda fun! The only time I dont like it is when the nozzle gets plugged and I have to stop to clear it. Watching all the old paint and rust flying off steel is cool, specially since its a LOT easier than a wire wheel on a grinder!
AirSpeed is offline   Reply With Quote
Old 10-25-2011, 07:21 AM   #11
Like anything,it's not so bad if you know what you're doing and have the right equipment. You can't expect a smooth ride going into something blind. But,that's how you learn. Or,you can read up and ask questions first and have a head start.
Old 10-25-2011, 07:39 AM   #12
no moa
no moa's Avatar
Well said!
Old 10-25-2011, 08:36 AM   #13
cdowns
cdowns's Avatar
i liked sandblasting and over a 30year span i've saved many thousands of dollars and ended up with a great final product
i learned real fast the importance of safty equipment the need for a respirator and the importance of covering every square inch of my skin
tricks for ease of containing the sand for recycleing were learned as well as having a breeze at my back to aid in vision and breathing safely
learning how to pile things up so that secondary things were getting preped while i was doing the main targeted piece increased effectiveness of the process
but yes it still was a nasty dirty job no matter what
the end of the process was the used sand went into compost pile to be used to repair/build my lawn
Old 10-25-2011, 09:04 AM   #14
no moa
no moa's Avatar
What are you guys using for sand? I used Black beauty, and a customer told me to get the Playsand at Lowes/homecheapo and it works great for the softer metals. I haven't tryed it yet.
I also want to buy another blaster for Plastic bead and walnut shells.
Old 10-25-2011, 09:27 AM   #15
dfwright
dfwright's Avatar
Every time I start to dislike blasting, I just get out the wire wheel for 20 minutes or so, and I'm quickly back to enjoying the blasting again...
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 10-25-2011, 09:32 AM   #16
cdowns
cdowns's Avatar
i use blasting sand it is well graded and sterile and has a far sharper cutting edge than "play sand"
play sand in many places is stored outside in the rain and is full of moisture, as well as not being that finly grated and depending on where and how it was mined can have minerals in it like salt that effect your longterm result
the brain surgen my brither in law couldnt see the need for "buyin" sand he just went to the beach and helped himself to a truck full when he was restoring a 58 chevy needless to say it rusted to the groud in 18months after being blasted to bare metal with that ocean sand
Old 10-25-2011, 10:00 AM   #17
I buy white silica sand graded for sandblasting. It doesn't matter what brand. Then,I use the appropriate nozzle for the grade of sand.
Old 10-25-2011, 10:20 AM   #18
BossHogg69
motor exploder
BossHogg69's Avatar
[QUOTE=msgross;4971802]best bet is to find an industrial trailer shop that does blasting... QUOTE]
This is exactly what I did too, and I'd do it again. Got a great deal.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 10-25-2011, 11:02 AM   #19
ChumBucket
OH, so that's how it works!
Y'all let the new guys live through the pain of doing stuff the hard way then telling them after the fact all the tips and lessons learned that would have made it better!
HAHA, just kidding, wouldn't have changed a thing about my experience. My boss told me to write the check to have someone else do it, I told him I was going to do it. He also told me to wear all the protective stuff, I did follow his advice on that one, but my wife was puzzled as to what all the black particles were doing in her clean shower last night.
The best thing of all for me is that I did it myself, on my truck and learned something new. In fact not only did I learn the hard lessons of sandblasting yesterday, I also "learned" how to weld, although I think welding is one skill that you never stop learning how to do.
Old 10-25-2011, 12:12 PM   #20
gearheads78
gearheads78's Avatar
Originally Posted by cdowns View Post
i
That made my day. Thanks for sharing that
gearheads78 is offline   Reply With Quote
Old 10-25-2011, 12:13 PM   #21
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
If building old trucks was easy, everybody would do it. Doing jobs like this that really suck is what separates the "haves" from the "have nots".
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 10-25-2011, 05:08 PM   #22
mlevario99
question for those who have done sanblasting, what kind of air compressors are you guys using, does it have to be really big, or what is the minimum size that you guys run.
mlevario99 is offline   Reply With Quote
Old 10-25-2011, 05:29 PM   #23
webfoot
Need a pretty good sized unit for big jobs. I have a 5 horse 80 gal unit and it runs constantly with the blaster.
-me
Old 10-25-2011, 06:18 PM   #24
AirSpeed
AirSpeed's Avatar
Pressure means nothing, what you need is airfllow. Most compressors will give you 120 psi but not all give you a lot of cfm, get a compressor that puts out the most cfm you can afford! Mine puts out 18 cfm and is just big enough to run my sandblaster. A large tank is also a plus, it will keep your compressor from running constantly and overheating the motor. Absolutely stay away from oil less compressors, they suck as far as I'm concerned!
Old 10-25-2011, 06:55 PM   #25
bigsnookmaster
bigsnookmaster's Avatar
I use oven cleaner and a pressure washer several times over on my frame, then drop it off at the local blaster and pick it up in a couple of days for about $150. It doesn't get much easier.
bigsnookmaster is offline   Reply With Quote
