Old 10-18-2011, 04:42 AM   #151
laid_out_70
laid_out_70's Avatar
Re: building my first lowered truck
i chopped the top of the frame for two reasons. first being when i did my 3 link i mounted my lowers a fraction of an inch from the ground, so cutting the bottom of the frame would have put my lower links into the ground, lol. reason two is then you have to Z the frame that much more to lay out if you cut the bottom of the frame off. looks like about 1.25" would lay rocker. i do have a c20 so that may be different for you. ive also read that you can drop the body about an 1" without modifying the frame.
ignore the crappy welds, rear is getting redone
hope that helps, let me know if you need anything else
My Build Thread. 70 C-20, SFBD, angled Z, 3 linked. impressive for a noob?
http://67-72chevytrucks.com/vboard/s...d.php?t=438132
laid_out_70 is offline   Reply With Quote
Old 10-18-2011, 08:02 AM   #152
L&L70
Thanks for the reply. That covers it perfectly. I actually am looking to lay pinch so it looks like an extra 3/4" is all I need. I'm planning on doing a z to match the front with the frame and will see what else needs to happed with the front end to lay it down. I've looked at your build more than once and it
s a detailed write up. Good Job
Matt
L&L70 is offline   Reply With Quote
Old 10-20-2011, 11:37 AM   #153
1sik7t2
dave
1sik7t2's Avatar
looks like all the "practice" is paying off...luuuking guuud mon....keep "down" the good work.....
Originally Posted by laid_out_70 View Post
todays progress, alot of sanding. lol
shaved all the holes except for the rear cab mounts since i haven't transferred the measurements yet
the tranny crossmember
the ridiculous pile i had after sanding all day
and my buddy started on the front crossmember
check out my build "DIRTY BURB"
1sik7t2 is offline   Reply With Quote
Old 10-20-2011, 03:46 PM   #154
laid_out_70
thanks man, cant wait to get it on the road some day. lol
Old 10-20-2011, 08:15 PM   #155
98layinframe
98layinframe's Avatar
great build so far, defiantly interested to see the rest of the front build! I love the amazingly simple idea of the angled Z cut to slide the suspension forward the inch to center the wheels!
98layinframe is offline   Reply With Quote
Old 10-21-2011, 01:05 AM   #156
laid_out_70
thanks for the interest man. hopefully i get going on the front horns tomorrow or saturday.
Old 10-21-2011, 11:04 PM   #157
laid_out_70
did some more forming on the Z today and threw on the suspension to stare at it.
the 2x3 under the tire and crossmember are to replicate the ground. lays 26" tall tire no problem. with the upper balljoint and bag maxed out it can lay on a 28" tall tire.
camber isnt to bad
Old 10-22-2011, 05:53 PM   #158
Kaidensdad
Damn. Best build ive found yrt. I am about to start my build. Planning on doin the same thing but i got a question. Ur rear bags seem to curve alot. Will that damage the bag?thanx
Kaidensdad is offline   Reply With Quote
Old 10-22-2011, 09:24 PM   #159
laid_out_70
thanks for the kind words. and no the bags are built to deal with odd angles. all you have to do when installing them it make sure the bag mounting surfaces are parallel to each other.
did some work today.
first i hacked off these things.
surface to transfer measurements.
tacked up
all tacked in and square. going to be a mission boxing that **** in.
Old 10-23-2011, 05:46 PM   #160
jbclassix
Junk Yartist
jbclassix's Avatar
are you planning on putting your steering gear, idler arm, and core support back in to see where you can add gussets?
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 10-24-2011, 12:37 AM   #161
laid_out_70
just gonna wing it, :P
let the winging it begin.
first i cut out the last stock crossmember.
plate 1 cut
plate 2 cut
plate 3 cut
plates tacked in
going to be a mission forming the curved plate, thats the plan for tomorrow.
also found two AC compressors that im going to convert to edc's. they have motorcraft tags on them. are those sanden compressors?
Old 10-24-2011, 01:42 AM   #162
laid_out_70
its a york after some research, stupid me. ill check out the shafts tomorrow and see which ones i have. hopefully they're 210's!
Old 10-24-2011, 11:20 PM   #163
jbclassix
Junk Yartist
jbclassix's Avatar
that's a good looking wing
-Jeremy
Rebuilding an NP205
Old 10-25-2011, 02:21 AM   #164
laid_out_70
thanks. all done with a cutoff wheel
looked at the shafts on the yorks today and they're 210's
did work on the chevy today.
first i had to build the inner frame plate out of scraps. lol
then got the rest of the plates cut out.
tacked em all in
then i welded both sides all up
after that i set the bumper on and pulled it off the frame jig.
cant even get a piece of paper under the frame
Old 10-25-2011, 09:43 AM   #165
67cheby
67cheby
67cheby's Avatar
wow...lotta work getting done !!
67cheby is offline   Reply With Quote
Old 10-25-2011, 10:49 AM   #166
502ms
502ms's Avatar
Very nice work
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 10-25-2011, 10:57 AM   #167
laid_out_70
thanks guys. might make some progress today
Old 10-25-2011, 08:17 PM   #168
laid_out_70
got a few hours in today. sanded the frame horns, welded on the core support mounts and mocked up the core support.
Old 10-28-2011, 09:56 PM   #169
laid_out_70
well i did a little bit of work on the frame. pulled the last bolted thing to the frame to clean it up and start sanding the entire frame. then after that is the front crossmember, going to be 1.5" square turned on edge with some plate gussets. also decided im building a tube core support.
Old 10-30-2011, 10:12 PM   #170
laid_out_70
made the front crossmember yesterday. 1.5" square on edge and rolled 1/8" plate for gussets.
Old 10-31-2011, 12:43 AM   #171
jbclassix
Junk Yartist
jbclassix's Avatar
I really like the rolled gussets. How long is your welding stinger?
-Jeremy
Rebuilding an NP205
Old 10-31-2011, 01:41 AM   #172
FnLow69
FnLow69's Avatar
Looking Good dude!
FnLow69 is offline   Reply With Quote
Old 10-31-2011, 03:09 PM   #173
laid_out_70
thanks man, good question, you can see the entire thing in the pic. whats the normal length?
Originally Posted by FnLow69 View Post
Looking Good dude!
thanks man. you been making any progress on your c10?
Old 10-31-2011, 08:33 PM   #174
Cameron 1137
Cameron 1137's Avatar
wow, great fab work as usual, NICE job!
Cam
1972 Chevy C/10 "Custom Cruiser Project" Build Thread
1961 Olds Super 88 (Daily)
1966 Chevy Corvair 500, "Marigold" SOLD
2005 Subaru Outback Wagon DEAD
2008 Pontiac G8, New Winter/Daily
Cameron 1137 is offline   Reply With Quote
Old 10-31-2011, 10:07 PM   #175
FnLow69
FnLow69's Avatar
Nope, still working on my dodge.
