Old 10-26-2011, 12:28 AM   #1
RocketKing
RocketKing's Avatar
Torque Clutch Converter
How did you guys wire up your TCC brake wire ?
I know you can use relays but I also read that you can use a later model brake switch signal that will fit in the original space.
Any suggestions?
Rex
RocketKing is offline   Reply With Quote
Old 10-26-2011, 09:25 AM   #2
Shon
Re: Torque Clutch Converter
do not have that wired up and I still get lock up and it unlocks. PCM controls it by MPH.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 10-26-2011, 09:41 AM   #3
RocketKing
RocketKing's Avatar
Really? Thats interesting. I was just going off the LT1swap site, so I figured most were wiring it up but maybe I was wrong.
Thanks for the heads up.
Rex
Old 10-26-2011, 09:46 AM   #4
Shon
If you want it to work, just have it tapped into the brake light from the factory wiring.
Many swaps we do also dont have VSS either :-O with no issues. but will say the ETC/DBW set ups look to be needing this information (VSS) but still trying to see if I can make it work without it....
Old 10-26-2011, 11:25 AM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I switched over to a 4post brake pedal switch; does the same thing as the stock 2 post on my 66 but gives you a place to hookup the 2 wires for tcc. I have a part # if you need it.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-26-2011, 01:07 PM   #6
RocketKing
RocketKing's Avatar
Thanks Shon and BR3W, I found that 4 prong switch and decided to go that route.
Thanks again!
Rex
Old 11-19-2011, 12:28 PM   #7
76stepside
76stepside's Avatar
A part # and even a picture if you have it would be great!
8.1l 496 4l80e
76stepside is offline   Reply With Quote
Old 11-19-2011, 01:36 PM   #8
Thealien
Thealien's Avatar
Just FYI you need the TCC connection to the brake switch for cruise control to work.
Not sure if any of you cared or not just passing on info.
Old 11-19-2011, 03:16 PM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Napa Part number is MP #SL186SB or Echlin #SL186, same thing, 2 different product lines. 4-p0st brake switch for vehicles with cruise control.
Old 11-19-2011, 06:43 PM   #10
76stepside
76stepside's Avatar
Thanks for the pic and info... I also found another post earlier and just bought one that uses a 99-04 camaro switch and bought the wiring pigtails to go with it.
I am going to put cruise on so I care... thanks also for the input!
8.1l 496 4l80e
Old 05-20-2013, 10:33 AM   #11
jks67ss396
Guys,
Bumping this back up. Do any of you happen to have the part number for the pigtail/connector for the tcc half of that brake switch? I got the switch itself and just have spade terminals on it for now, but would like the connector for later
thanks
jks67ss396 is offline   Reply With Quote
Old 05-20-2013, 02:56 PM   #12
76stepside
76stepside's Avatar
I don't have the part number arailable but I got both the switch and the pigtail from Rockauto.com. Hope this helps.
8.1l 496 4l80e
Old 05-20-2013, 06:33 PM   #13
jks67ss396
i cant seem to see the connector on rock auto... just the switches. Do you remember where you saw it/what section etc?
thanks!
Old 05-20-2013, 07:08 PM   #14
76stepside
76stepside's Avatar
I got a brake light switch for a 99-04 camaro. It has six wires, 2 plugs. One plug has two wires the other has four wires. Plug with four wires part number pt483 plug with two wires part number 1p1698 brake switch part number d889a. Look under 99 camaro then electrical connector for the plugs and electrical switch and relay. There are other year swiches that you can use to make this work. Hope this helps.
8.1l 496 4l80e
