Old 10-26-2011, 08:44 AM   #1
Christiansok
Moving Axles Forward
I figured the people in the 4x4 section would be more familiar with axles riding on leaf springs and what it takes to move them. From what I can gather my truck is a 67-72 body on a 73-? 4x4 frame. Looking at the truck from the side the wheels don't seem quite centered in the wheel wells of the body. The front looks like it needs to be shifted forward maybe an inch, the back a little less if any. What is involved in shifting the axle forward this much? Is there a better way to go about lining the wheels up with the body (i.e. moving the entire body) or will getting newer front springs move the axle forward? My front springs have a slight downward curve to them now and are no long flat. Any suggestions are appreciated. Thanks.
Christiansok is offline   Reply With Quote
Old 10-26-2011, 09:37 AM   #2
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Re: Moving Axles Forward
DIY4X has a B52 kit that will allow you to adjust to bigger springs that can also be used to move your springs forward. The other way is a longer shackle in the front might move it a little. As for the back, i got nothing. Good luck
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 10-26-2011, 07:05 PM   #3
onebadbowtie
onebadbowtie's Avatar
zero rate add a leaves http://offroaddesign.com/catalog/Zero%20Rates.htm
James
94' Chevy K1500 Extended Cab 4x4 5.7
72' Chevy LWB K10, 350, SM465, NP205 Project "Daily Driver"
onebadbowtie is offline   Reply With Quote
Old 10-29-2011, 02:56 AM   #4
kurts704
I just lifted my 67 with 69-72 springs which everyone says won't work. I put it together and the pin was off, so the wheel was too far forward. I got a 1 inch aluminum lift block and drilled another hole for the pin in it 2 inches rearward. Lines up perfect now. You can probably do the same on the rear on your truck.
67 K10 stepside (driving project)
06 Tahoe (family truckster)
84 vette (fast toy)
00 Harley Fatboy (2 wheel toy)
67 Mustang (project)
kurts704 is offline   Reply With Quote
Old 11-10-2011, 06:02 PM   #5
mudmizer
mudmizer's Avatar
If you go into some of the circle track racing catalogs or Summitt, you can find 1" lift blocks that have an adjustable pin just for that sort of application.
68 4x4, 454, 4 speed, disk brakes both ends,
Sold my 69 SS396 Elcamino when young & stupid
mudmizer is offline   Reply With Quote
Old 11-11-2011, 04:09 PM   #6
Davidmichael
Davidmichael's Avatar
If you want to lift it, get the B-52 brackets, and a shackle flip for the rear. If you just want to move the axles a bit, get the zero rates. They get bolted into the spring pack and are not blocks. They are actually considered a zero rate spring. Then depending on what drive shafts you have, you may need to get it lengthened or if they have enough in the slip, you could possibly pull it off.
86 Suburban 2WD = rolled it and totaled it
83 LWB STD Cab 4x4 = went to the scrapper. Was my baby.
84 Suburban 2WD = stripped it/ scrapped it
81 8 foot bed made into a trailer
86 Suburban going to be made into a trailer
91 Suburban 4x4 = that's my baby
00 S10 Xtreme STD Cab
01 S10 ZR2
Davidmichael is offline   Reply With Quote
Old 11-17-2011, 03:18 AM   #7
joe231
joe231's Avatar
Zero rates are the way to go.
CHEVY ONLY
joe231 is offline   Reply With Quote
