10-30-2011, 10:24 PM | #1 |
how to find what axle gear do i have
is there any test that i could do at home to find out what ratio do i have
10-30-2011, 10:50 PM | #2 |
Re: how to find what axle gear do i have
Chalk the front tires
Jack the rear of the truck up. Put jack stands under the rear housing with the tires off the ground. Mark the inside of a rear tire with a piece of chalk or tape, pointed towards the ground Mark the drive shaft again with chalk or tape Turn the drive shaft counting the turns until the tires makes a complete revolution. 2 3/4 turns would be a 2.73's 3 3/4 turns would be a 3.73 4.25 turns 4.11's or 4.30's (closer to 4 = 4.11)
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
10-31-2011, 10:03 PM | #3 | |
10-31-2011, 10:43 PM | #4 | ||
You can either pull the cover off and count the ring gear teeth and pinion gear teeth and divide the ring gear by the pinion. Example: 41 teeth on the ring and 11 teeth on the pinion (41 divided by 11) and you get 3.73, which is what my truck has in it. Or you could just look at the ring gear and it should have the tooth count stamped in the outer edge of the ring gear. It will have some numbers and one of the sets of numbers will be 41:11, if you have 3.73's. Hope that helps. -Aaron |
11-06-2011, 12:26 AM | #5 |
what axle would fit my 65 c10 truck with 5 lug. my truck axle all ready have a 5 five. the axle i have is 4:11. some guy qoute me 600 for new 3.73 gears.
