#2101 |
Re: ** YOUNG FRANKENSTEIN ** The truck Chevrolet should have built.
Goes to show...There is always more than one way to skin a cat.
71 Ol' Blue: http://67-72chevytrucks.com/vboard/s...d.php?t=474752 Carving the Jake-olantern: http://67-72chevytrucks.com/vboard/s...d.php?t=679537 |
#2102 |
67cheby
![]() Join Date: Sep 2008
you my friend are a PROBLEM SOLVER !!
#2103 |
time for video of e-brake slides
#2104 |
6>8 Plugless........
![]() Join Date: Sep 2007
Great work and ingenuity!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#2105 |
Lucky Teter at the wheel
And on tonight's episode of As The Wrench Turns, we have a bed that got mounted and a little shot-o-bling.
Drew YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!) The Bride is currently under the knife!
#2106 |
very nice!
#2107 |
67cheby
looking good !!
#2108 |
Very nice!
#2109 |
VA72C10
![]() Join Date: Mar 2008
Looking good.....although you really need to clean your bed
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#2110 |
#2111 |
VA72C10
BTW....you're nearing #1 on the views.....231K+ as of tonight!
#2112 |
67cheby
i know it is a little petty thing but with the work you have put in , i think those bolts through the bed floor need to have a round head instead of the hex head to blend in better, maybe a round allen headed bolt ?
#2113 | |
Since I am planning on using the truck, I figured it was insane to spend $1000 on a bed floor and then worry about denting or scratching it. Yes, I hope the truck is magazine worthy, but that is a secondary consideration to my using it everyday.
#2114 | ||
"Oh well, it's a driver."
- JB - '93 C1500 SHORT/FLEET SILVERADO, 350/4L60E ![]() Quote:
#2115 |
Tonight's episode begins with painting the radiator support and new radiator mount satin black. A few more coats tomorrow and it will be ready to assemble.
Then I moved on to the shift linkage. I welded and extension on the shift ear I cut off to clear the brake booster, then assembled the Kugal stainless steel shift linkage. http://www.kugelkomponents.com/zenca...&products_id=6 I very carefully fit and adjusted, then shortened the rod twice so as not to cut too much off at once. The throw is now perfect and I get all gears to click nicely, it even lines up on the column indicator right. Then I read the wiring diagram and ended up only needing one wire on the right electrical block -green temp sensor wire for gauge. I may want the switched brown wire for something, so I left it for now.
#2116 |
Little by little.
#2117 |
#2118 |
VA72C10
More good progress. Shift linkage looks good as does the rad support!
#2119 |
#2120 |
lovin' the lowcountry
Are you keeping the mechanical fan or going with an electric set-up? sorry if you already answered this but that chip in the fan blade made me think about it, haha.
Chris 29461 72 SWB stepside ![]() 71 SWB stepside ![]() DRIVE IT LIKE YOU STOLE IT! |
#2121 |
Mechanical, because it is free and installed!
#2122 |
These pics are more fun to look at.
Where do these little square rubber blocks go? They came with my tailgate bumpers kit.
#2123 |
67cheby
SWEET they are bumpers for the tailgate !!
#2124 |
Where?? got a picture?
#2125 |
![]() Join Date: Jul 2010
Have you thought about doing tha stop light mod that i've seen on here using that factory cargo light..
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
