Old 11-01-2011, 09:35 PM   #1
Mattman2010
Mattman2010's Avatar
6.2 Diesel Help
I finally got my 6.2 Diesel running in my crew cab. When I give it some throttle and then let off the throttle really fast the truck dies. It idles fine when i first start it up and if I don't ease off the throttle then it will die. If i hit the throttle and bring up the rpm and slowly let off it will stay running. The engine is a 84 Military 6.2, Not sure if it came out of a truck or blazer.
I also have a question about hydro-boost brakes. I bled my brakes with out the hydro-boost having any fluid in it. Now that the truck runs and I have some fluid in it the brakes will go all the way to the floor, but then the hydro-boost starts to push my foot back up, it does this very slow, is this because the system is not fully bled? How do you go about bleeding the system?
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 11-01-2011, 10:03 PM   #2
rcbildr
rcbildr's Avatar
Re: 6.2 Diesel Help
You might find the answer over at dieselplace.com. Sounds like your lift pump might be going bad or your fuel filter(s) need to be replaced. If I have time, I'll look thru my haynes manual when I get home from work to see if there is anything about that too.
Not sure about the hydro boost. Is your power steering fluid at the right level.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 11-02-2011, 12:23 AM   #3
lindstromjd
Gentleman Jim owner x2
lindstromjd's Avatar
Re: 6.2 Diesel Help
What kind of fuel filter do you have? I noticed in your pictures of everything that you had the box style... those things are a piece of crap. Change it out as soon as you can.
If that's not the problem, then I'm thinking that your IP might need gone through.
1975 GMC Gentleman Jim #1
-357 / 700r4
1975 GMC Gentleman Jim #2
-350 / TH350
lindstromjd is offline   Reply With Quote
