Old 11-01-2011, 01:12 AM   #1
markallen
markallen's Avatar
250 i6 fuel economy w/o sacrificing HP
right now im running a stock 250 with a T-5 tranny and a 3:07 rearend (getting about 15 mpg) im thinking about keeping the 6 and hopping it up a little instead of changing to a 350. i was wondering if anybody had any suggestions as to hopping it up with out going below 12 or 13 mpg
markallen is offline   Reply With Quote
Old 11-01-2011, 09:14 AM   #2
geezer#99
geezer#99's Avatar
Re: 250 i6 fuel economy w/o sacrificing HP
You're looking on the wrong end. Your mpg is suffering cause of the O/D and 3.07 gear.
You'd get better mpg with more gear like 3.73 or 4.10. Less throttle opening equals more mpg.
However nothing wrong with some hop-ups. Headers and a 4 bbl intake with small 390 holley will help.
With your gearing a 350 would probably get better mpg though.
geezer#99 is online now   Reply With Quote
Old 11-01-2011, 09:55 AM   #3
Fantom
Fantom's Avatar
I keep telling you to keep the I-6......Add 4 bbl, headers & chrome. Maybe a small cam. It's just gas!!!!
(did you figure out who I was yet?)
Fantom is offline   Reply With Quote
Old 11-01-2011, 12:57 PM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
You could also look around the BB.Someone has done a FI system on a 6.IIRC he used one designed for a Jeep but it worked well and his milage and performance are both improved.The 3:73 gears,FI and a header shoukld make for good milage and keep most street 350's on their toes.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 11-01-2011, 04:18 PM   #5
MARKDTN
Howell makes a FI system for a straight 6 jeep that could work with a Chevy 6.
http://howellefi.com/jeep-tbi-products.html
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 11-01-2011, 04:21 PM   #6
markallen
markallen's Avatar
haha yeah i fiqured out who you were fantom
Old 11-01-2011, 05:33 PM   #7
markallen
markallen's Avatar
i dont understand why i would get better mileage with lower gears like 3.73 or 4.10 i thought higher gears = more mileage
Old 11-01-2011, 05:50 PM   #8
longbed67
longbed67's Avatar
Get yourself a wideband and look at your #'s the 3.07 is to low of a ratio for the h- power and torque curve of a stock 250, thus you must put more foot into the throttle, thus richening the mix and killing fuel economy. I drove through the mountains with a 3.73 and a stock 250 and got 17+ all day long on my trip back from washington. If you want to keep the 3.07 you can but do a cam change, headers, clifford intake, holley 4bbl carb (get it tuned properly), and an hei ignition and you will have about 75-100 more hp and ftlbs torque and you have better fuel econ. visit www.12bolt.com, tom has a lot of info and products at very good prices that will help you out on the 250.
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
Old 11-01-2011, 07:10 PM   #9
68gmsee
Active Member
68gmsee's Avatar
I agree with going sbc. Since your truck is not completely original I'd go with a 350 and keep the rear end as it is. You'd have quite a bit more power and it would be alot cheaper than upgrading the 250.
I converted my 69 to a 350/350TH, swapped the rear end for a 3.08 and my mpg was about 16 on the highway. I was getting about the same or a little less with the original 250 but the 350 gave me quite a bit more power.
I keep the 250 in my 68 GMC because it's totally stock except for power brakes and power steering and I just cruise in it every now and then.
68gmsee is offline   Reply With Quote
Old 11-01-2011, 07:18 PM   #10
longbed67
longbed67's Avatar
if you are going to do a swap... why not do something that these trucks had in them like a 327 with a good compression your making the same power as a 350 if not better and your not doing a run of the mill swap...
Adam
(608) 214-8706
Old 11-02-2011, 01:57 AM   #11
markallen
markallen's Avatar
what rearend gears would give the most mileage after i get headers and a small cam?
Old 11-02-2011, 06:03 AM   #12
longbed67
longbed67's Avatar
If you do keep the 250 L6 motor AND do the power upgrades, I would keep the 3.07 I am currently in the process of turbocharging my motor and doing a LOT of head work and am going down to 2.76 gears to make up for not having an overdrive trans. In doing the power upgrades you will have the power to keep out of the throttle and improve fuel econ. but with more power comes the want to get on it to show off...
Adam
(608) 214-8706
Old 11-02-2011, 09:58 AM   #13
FL71C10
I would think the 5 speed transmission would help make up for the lower rear end gear ratio.
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 11-02-2011, 10:16 AM   #14
faribran
my truck used to have the 250.... i have since upgraded to a SBC....... more power and better gas mileage..... all around more user friendly..
faribran is offline   Reply With Quote
Old 11-02-2011, 10:16 AM   #15
longbed67
longbed67's Avatar
Never thought to ask is the 15 MPG in town or highway? if your going into 5th gear on the highway with the OD .73:1 gear your going to throttle harder than if you kept it in 4th with the straight drive 1:1 gear. If it is in town... Get a proper tune on the carb jetting and ignition timing, and stay out of the throttle...
Adam
(608) 214-8706
Old 11-02-2011, 01:34 PM   #16
brad_man_72
the boat guy
brad_man_72's Avatar
there's a reason everybody is doing ls swaps on these trucks. I get better mpg pulling my boat 70mph. You can buy alot of gas for what the swap is going to cost you...
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 11-02-2011, 03:20 PM   #17
Ackattack
Ackattack's Avatar
You could put a TBI injection system on it.
How about an electric fan?
Try driving in 4th gear on the highway and see what that does to your mileage. That's free and might be worth a shot.
Ackattack is offline   Reply With Quote
Old 11-02-2011, 03:57 PM   #18
R.L.
R.L.'s Avatar
What kind of gas mileage are you getting now and how does it preform street wise? Does it not keep up with traffic as is?
R.L. is offline   Reply With Quote
Old 11-02-2011, 05:38 PM   #19
Z1971
Z1971's Avatar
I would keep the 250. Everybody (including me) has a SBC. Try a GM HEI and headers first. Tom Langdon at Stoveboltengineco.com will get you a rebuilt factory HEI with new cap and coil for $95. He also has rebuilt Holley Weber Progressive 2-Barrel Carburetors for $80. You will need a $15 adapter to fit the stock intake. Clifford has headers and their 4 barrel intake is better than the Offy. I would suggest a holley 390 and Clifford 270cam if you want to change your intake. Tom Lowe at 12bolt.com has some dyno runs with the 270 cam where he got 270hp from 250 inline.
The heads are the real weakness of the Chevy inline. Bolt-in lump ports really help the flow. Tom has everything even turbo manifolds. http://www.12bolt.com/home He also has several projects on Inliners International forum.
Z
1971 LWB Ochre
Z1971 is offline   Reply With Quote
Old 11-02-2011, 05:45 PM   #20
ol_skool_chevy
ol_skool_chevy's Avatar
Sorry but I have to agree with geezer#99.
your Much better running the 3.72 gear with that t-5
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 11-02-2011, 07:20 PM   #21
SOON2BLAZE
SOON2BLAZE's Avatar
ditto and the 3.73 gears. Still alot cheaper than a sbc swap. I'm guessing the 3.07s are the stock 40 year olds.
SOON2BLAZE is offline   Reply With Quote
Old 11-05-2011, 01:40 AM   #22
markallen
markallen's Avatar
a guy my dad works with said that if you put a performance cam in a 6 cylinder the motor will not hold up bc it is not made to do things like that with...is there any truth to this
Old 11-05-2011, 09:30 AM   #23
You will typically get your best MPG when your vehicle is running around it's peak torque RPM. That way at a steady RPM, your truck/car is working more efficiently. Sometimes a lower rearend gear (higher number) will get your better MPG. If most of your driving is highway, then you would probably do better mileage with a 3.42/3.73 rearend with the 250. If most of your driving is in town, then I would stay with the 3.07
As far as the engine not holding up to a cam, baloney. Now just just doing a cam and not looking at the rest of a 40 year old motor is asking for a problem.
Freeing up your exhaust flow with headers or a good split manifold, possible an intake and carb change will also probably help. Before I would do any engine mods, I would check my over condition of the engine first. How's the compression, carb settings, timing, etc... As mentioned a good HEI will help. BTW your tire size will effect your MPG also. Large low profile means more resistance, thus it takes more to push the vehicle.
Remember you are moving a LARGE brick. Try things you can afford, but keep the truck running. Don't lose the fun of driving it.
Old 11-05-2011, 09:42 AM   #24
68gmsee
Active Member
68gmsee's Avatar
Way back in the 50's and 60's there were quite a few of them in drag and speedway circle racing. I've seen some of these sixes out run V8's in the 1/4.
These engines can hold up pretty well if built right. Check this Youtube video. Chevy 250 on a dyno.
Old 11-05-2011, 12:03 PM   #25
longbed67
longbed67's Avatar
Depending on whether your tranny is a standard t5 with the .63 OD gear or the close ratio t5 with the .74 OD gear this is what your RPM bands look like with a 3.07 rear and 255/60R15 tires for a total tire height of 27.05" If it is the standard t5 the ~1300 rpm at highway speed would explain the low fuel econ. because you dont have enough power to push it down the road.
Adam
(608) 214-8706
