Old 11-02-2011, 12:40 PM   #1
pstifel
'76 c10 gauge cluster swap
Hi all,
Trying to replace my '76 chevy c10 idiot light cluster with what I think is a (73-75) factory tach cluster with gauges (because it has a mechanical oil pressure gauge and ammeter, not volts). The FAQs cover the pre-73s, but not these. This is asking a lot, so I will not be surprised if I get no responses.
The principal is straightforward - rearrange the cluster plug pins to support the new cluster but it's not a clean swap. Any light shed on the following would be very much appreciated:
1. The ammeter gauge in the "new" plug calls for 2 pins (wires) - a black wire (ground?) and a black and white wire - that the old harness does not have.
2. What do I do with the orange generator/ignition wire and the brown generator wire, both of which are not included in the new gauge cluster? Do they now go to the ammeter or removed?
Thanks for anything, however trivial.
Peter
pstifel is offline   Reply With Quote
Old 11-03-2011, 04:18 PM   #2
pstifel
Re: '76 c10 gauge cluster swap
Ok, how 'bout this: anybody have a schematic or wiring diagram that shows the gauge cluster pin positions for a '75 c10 with gauges and tach?
(the FAQ info has info for lights and gauges w/o tach, but not gauges WITH tach)
Thank you!
Peter
Old 11-03-2011, 04:33 PM   #3
RandyP
Getting Old; Going Broke
RandyP's Avatar
http://www.73-87.com/7387garage/inte...achometers.htm
73-75: Amp gauge instead of volt gauge. This cluster will only work for these three years only and are NOT serviceable since they are completely sealed. Just plugging one of these clusters in a 76 and up truck will result in instant meltdown upon turning the key.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 11-03-2011, 05:12 PM   #4
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
You cannot use an amp cluster with anything but a 73-75 unless you plan on some major rewiring.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 02-13-2012, 08:07 PM   #5
88Jimmy4x4
88Jimmy4x4's Avatar
My truck is a 76 with mech oil and volt gauge. I bought a tach cluster and the guy said it was from 76 and it too has mech oil gauge and volt meter.
Is this a plug-n-play since both have mech oil and volts?
Will my gas gauge work in new location?
I just dont want to burn anything up LOL
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
