11-04-2011, 12:35 AM | #1 |
car pattern rotors??
I'm changing my 69 over from 6 lug disc brakes to 5 lug.....does anybody sell a direct bolt on rotor that is 5 on 4-3/4.The choice of wheels seems endless.also is there any problems going with the smaller pattern when i have the rear axles done??
11-04-2011, 01:23 PM | #2 |
Re: car pattern rotors??
71-74 G10 chevy vans ,some used the light brakes with the 4 3/4 bolt pattern.. I do not know if the bearing size is the same..but it should be..that will be one to try..
Its the same rotor as the 77 caprice..This may work for you. |
11-04-2011, 02:06 PM | #3 |
i am in the middle of doing this... i had the front truck rotors redrilled for the 4 and 3/4 pattern.. the only problem i am having is the inner wheel making contact with the lower a-arm.
11-04-2011, 02:31 PM | #4 |
Actually, a board member sell rotors for 67-72 trucks that use a 5 on 5 3/4 bolt pattern.
http://67-72chevytrucks.com/vboard/s...d.php?t=489190 Last edited by Rochlow; 11-04-2011 at 04:00 PM. |
11-04-2011, 03:39 PM | #5 |
81-87 light duty spindle , ball joints , etc. , use a 1987 camaro h.d. brake rotor , 5x4 3/4 pattern with 12mm studs , done this a couple times with all factory stuff
11-04-2011, 07:20 PM | #6 |
70 SWB STEPSIDE 70 BLAZER 09 challenger |
