Old 11-05-2011, 05:57 PM   #1
DBear
DBear's Avatar
Which Rear Differential??
Anyone know what years and what models have a 3.73 rear diff, that would swap into my '64 Chevy 4x4 Burb? I would like to find something that bolts up with no problems?
DBear is offline   Reply With Quote
Old 11-05-2011, 06:19 PM   #2
Dunenutt
Newbee
Dunenutt's Avatar
Re: Which Rear Differential??
The 10 bolt from the 85 blazer that I used on my 69 truck had 3.73. I believe its the same axle for pickups of that era. You may or may not have to move the perches though. Look for the two flat ears sticking out from the lower part of the diff, while looking at the cover, it's a good indicator of the 8.5 ring gear. Then check for the tag, if its not there, look for 41 11 stamped on the ring gear.
Dunenutt is offline   Reply With Quote
Old 11-05-2011, 06:58 PM   #3
Shooters_7
Keep the 12 bolt and rebuild with 3.73s
Shooters_7 is offline   Reply With Quote
Old 11-06-2011, 12:04 AM   #4
Captainfab
60-66 Nut
A 10 or 12 bolt from '63-'87 from a K5 or K10 should bolt up. But from about '73 and up the shock brackets will be different than what you have now. Another 12 bolt would ensure that your current U-joint will bolt up.
Old 11-06-2011, 08:37 AM   #5
DBear
DBear's Avatar
That is great info fellas.....there was a pop back by the rear end and now it will not go in reverse bit will go forward. Any ideas what that could be? I think rebuilding the rear end that is in it would be idea....not sure what that kinda repair could cost though!
