Old 05-12-2011, 04:48 PM   #226
VA72C10
VA72C10
VA72C10's Avatar
Re: Project Orange to Green
good progress!!!
Old 05-12-2011, 05:50 PM   #227
late68
late68's Avatar
Now time to feel like your getting someting accomplished after your done with that frame!......lol
late68 is offline   Reply With Quote
Old 05-12-2011, 07:50 PM   #228
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
I hope so. Although I love welding, it feels like I'm just going in circles
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 05-13-2011, 12:21 AM   #229
late68
late68's Avatar
Since you love welding so much you can come over and weld up my new roof and roll pan! lmao.
Old 06-28-2011, 09:55 AM   #230
BACKYARD88
BACKYARD88's Avatar
Finally got some work done. The frame is cleaned, primed and undercoated. I also got some of the other parts painted and installed.
-Mike Owen-
Old 06-28-2011, 10:02 AM   #231
67cheby
67cheby
67cheby's Avatar
LOOKING GOOD !! keep it up
67cheby is offline   Reply With Quote
Old 06-28-2011, 11:32 AM   #232
VA72C10
VA72C10
VA72C10's Avatar
Nice progress!!! Looking NICE!
Old 06-28-2011, 08:34 PM   #233
late68
late68's Avatar
About time you did something!
1968 C10 SWB Dropped 5 in tha back 3 in tha front
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=470902
Old 07-06-2011, 04:01 PM   #234
yawdie1
yawdie1's Avatar
Very nice progress! more pix please
1950 chevy PU work in progress.
yawdie1 is offline   Reply With Quote
Old 07-06-2011, 04:21 PM   #235
mcbassin
Still Learning
mcbassin's Avatar
Frame looks great. Can't wait for more pics....
Old 07-19-2011, 12:25 AM   #236
late68
late68's Avatar
Any new updates Mike???
Old 10-25-2011, 12:43 AM   #237
Mike Bradbury
Mike Bradbury's Avatar
Originally Posted by BACKYARD88 View Post
This is the best I've got. It's just a power rack for a 93 Mustang I picked up from NAPA.
Hey Mike
I just picked up a rack out of a late 90's mustang and I was wondering what i should expect with the mod? Did yoy use the same pump off the Chevy or did you have to use the Ford one? Did you notch the frame because you were going to lay frame and you needed clearance and would I have to do the same notch being only lowered 4 inches up front? and I am assuming that you got some sort of coupler to marry the two makes together at the rod ends. What steering mods are necessary? did you fab your own cross member to mount it to? I cannot see from the picture how you mounted it.
Thanks,
Mike
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline   Reply With Quote
Old 10-25-2011, 09:01 AM   #238
smbrouss70
smbrouss70's Avatar
He has a dropmember.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 10-25-2011, 11:45 AM   #239
BACKYARD88
BACKYARD88's Avatar
Originally Posted by Mike Bradbury View Post
Hey Mike
Thanks,
Mike
As Steven said I have a Dropmember, but I'll answer what questions I can. You can have hoses made to use your stock pump with the Ford gear. The frame is notched because of the raised height of the Dropmember, I doubt you would need to notch yours. Porterbuilt will sell you the aluminum sleeves and rod ends to connect the rack to your spindles, then you will need to get joints and shaft to connect it to your column.
-Mike Owen-
Old 10-25-2011, 03:21 PM   #240
Mike Bradbury
Thanks Mike, I did not know the drop member had holes that lined up for the rack. I will just fab one up to match the holes to replace my stock forward cross member. Thanks for the help.
Old 10-25-2011, 03:26 PM   #241
BACKYARD88
BACKYARD88's Avatar
No problem
-Mike Owen-
Old 11-06-2011, 10:29 PM   #242
BACKYARD88
BACKYARD88's Avatar
No great progress but I have been getting some parts cleaned, painted and installed.
-Mike Owen-
Old 11-06-2011, 11:51 PM   #243
Mike Bradbury
Looks good Mike, What is the mod for your bed? Are you going to raise the bed floor and weld it in the new location?
Old 11-07-2011, 09:35 AM   #244
BACKYARD88
BACKYARD88's Avatar
Probably won't be a bed floor at all. I'll have to see how much room is there after the fuel cell is in. I would like to do a raised wood floor but if it's going to be 3 or 4 inches from the rail there's really no point.
-Mike Owen-
Old 11-07-2011, 01:17 PM   #245
bchaney
bchaney's Avatar
hey if u dont mind i would like to come by and check out ur project. i need some ideas to get my start need someone to help point me in the right direction.
bchaney is offline   Reply With Quote
Old 11-07-2011, 01:30 PM   #246
smbrouss70
smbrouss70's Avatar
If you don't have a bed floor, then where are you going to put your ice chest and chairs when you're cruisin around at CTC?
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 11-07-2011, 03:07 PM   #247
BACKYARD88
BACKYARD88's Avatar
No problem, just let me know when.
Good point, I may have to rethink this idea
By the way, I bought some of those rubber isolators for the compressors and they make a world of difference!
-Mike Owen-
Old 11-07-2011, 03:29 PM   #248
smbrouss70
smbrouss70's Avatar
Cool, I'm glad they worked.
BTW, my bed is now 13" deep after raising the bed floor 6.5", of course I'm not quite as low as you are in the rear. The top of the ice chest sticks out, but it "should" stay in the bed, even during evasive maneuvers.
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 11-07-2011, 03:51 PM   #249
smbrouss70
smbrouss70's Avatar
Hey , I just noticed that your compressors are mounted laying on their side. According to one of the guys that works for Viair they should always be mounted with the cylinder pointing up to help them dissipate the heat from the motor.
Here's a link to the S10 forum where they are discussing this.
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 11-07-2011, 07:24 PM   #250
BACKYARD88
BACKYARD88's Avatar
Thanks, do you know the trouble I went through to mount them like that? Now I have to go back and change it
-Mike Owen-
