Old 11-08-2011, 10:16 AM   #1
Iron Hauler
Iron Hauler's Avatar
A couple cab light questions
I have a 1970 4x4, I want to add the lights on top of the cab, what would be the correct light? Are they easy to install in a truck not factory equipped?
Iron Hauler is offline   Reply With Quote
Old 11-08-2011, 12:49 PM   #2
slomotion
Old Duffer
slomotion's Avatar
Re: A couple cab light questions
First off, Welcome Aboard!
As for the lights, "easy" is a relative term. Seems there was a thread on this a while back, but in a nutshell, there are after market lights that fit the curvature of our cabs. Check out the board's vendors for them. Marking out the locations for the lights is probably the most critical part of the whole process. You should have the lights on hand so you know where they should be located in relation to this curve. The second hard part is drilling 15 holes in your roof.....three for each light. Two for the mounting screws, and a slightly larger one for the wire. There is a thread here where someone described a clever way to run the wire up the "A" pillar using string and air pressure....I'd love to give them credit, just don't remember who off hand.
Not trying to avoid the question, but run a search (it's on the tool bar right under your sign-in) on cab lights, and I'm sure you'll get everything you need without a lot of duplication here. In the search box type in "mounting cab roof lights." Part way down the list the air trick, and a mounting sequence will show up.
Welcome
'68 Short C20 Flatbed Dually
w/ 292 4bbl, Langdon cast headers,
and WC T5 trans.
'81 G10 Shorty Van
"Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers
"Under promise, then over achieve."
slomotion is offline   Reply With Quote
Old 11-08-2011, 07:11 PM   #3
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Correct cab lights from factory used a special roof as compared to normal roofs. They had raised pods for clearance lamps, though like stated above. You can make some aftermarket lamps work. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 11-08-2011, 08:21 PM   #4
1972RedNeck
1972RedNeck's Avatar
Do '69 style lights need the pods?
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 11-08-2011, 09:31 PM   #5
71blksuper4x4
SWB 4x4 Collector
yes, 69's need the pods for the hockey puck lenses. Trevor
TREVOR
Old 11-09-2011, 06:28 AM   #6
The factory 69-up clearance lamps will fit right on the roof without pods. It just won't be factory correct. Only people who really know these trucks will notice and that's only if they look for them. I've always wondered why GM made that special roof panel. The '73-ups didn't use anything special for the same lights.
Old 11-10-2011, 10:11 PM   #7
Iron Hauler
Thanks for the help guys, I think I'll try and find a set of factory lights and harness and then take it from there.
Old 11-10-2011, 10:46 PM   #8
C10 - C90 Bill
C10 - C90 Bill's Avatar
In my opinion, the best ones to go with on a roof that doesn't have the "Raised Pods" are the Yankee 77's. Yankee 77's are also the ones used on 2-Ton and 3-Ton Trucks from at least 1960 to the mid 70's.
And I agree that placement is just as important as the Lights themselves.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
C10 - C90 Bill is offline   Reply With Quote
Old 11-11-2011, 07:37 AM   #9
My '71 Custom/30 tow truck had a no clearance lamp cab swapped on and those are what I got for it. The truck is more about being equipped than being original (and a little more chrome doesn't hurt)
Old 11-12-2011, 01:03 AM   #10
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
I agree the #77 Yankee would be a good way to go and is the correct light for a truck that was not equipped from the factory..these were the lights that were in the GM Truck Accessory catalog all the way up into the eighties. You can still buy them today under different names...the one in my 1st pic is a Truck-Lite 1312a. No matter what brand you buy, even the old NOS Yankees come with a very cheap stamped out foan rubber pad..your best bet is to ditch these and find a set of pads from a factory installed 67/68 set of cab lights..these are a much better molded rubber base and is a GM part.
If you want to run the 69 to 72 style I wouldnt even try using the factory lights or harness..the factory harness uses a 2 wire setup that runs across from one light to the next and all the way down the a pillar. The factory light also requires you drill a 1-3/16" center hole in your roof for each light..plus the lamp base that plugs into the rubber base hangs down way to far..thats the reason for the pod I believe. there just isnt much room between the inner and outer skin on these roofs. You can use a Truck-Lite 1313a and drill as small as a center hole as you can work with..they sit flat on the roof and the lamp base is on the top side of the pad. You can run your ground wire to one of the mounting screws and all you have to run across the cab roof is one wire to tie each power wire in to..much easier than the factory setup on a standard roof.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 11-12-2011, 01:10 AM   #11
BLAZERMAN
BLAZERMAN's Avatar
1st pic showing the bottom of the factory base with lamp base and part of the wiring harnesss.
2nd pic shows the bottom of the 1313a .
3rd pics shows the 2 different style lamps used from 69 to 72..the one on the left is the 69/70 hockey puck style..the one on the left shows the 71/72 firemans hat style.
Old 11-12-2011, 01:22 AM   #12
BLAZERMAN
BLAZERMAN's Avatar
Just a few more
1st pic shows the top of the 1313a base and its lamp holder.
2nd pic shows the 2 different rubber pads
3rd pic is a 1312a with clear lens and amber bulb for something a little different.
4th pic is a factory rubber base with a stepside backup light lens that you can use an amber bulb with.
Hope this clears some things up for ya and maybe gives you a few different options.
Old 11-12-2011, 01:59 AM   #13
BLAZERMAN
BLAZERMAN's Avatar
Gotta ad this! this is a vid by Tx Firefighter on how to run the wire down the A pillar....this has always been the part I hated most....now I cant wait to try this trick myself!
Old 11-12-2011, 02:05 AM   #14
BLAZERMAN
BLAZERMAN's Avatar
And a link to the Truck-Lite [Signal-Stat] website.
http://www.truck-lite.com/webapp/wcs...0314&langId=-1
Old 11-12-2011, 10:31 AM   #15
slomotion
Old Duffer
slomotion's Avatar
Feb 20 2011 VID00001 - YouTube
Thank you Blazerman! That was the trick I was talking about in post #2. I was bummed that I had already gone the fish-wire route to wire mine. I'm looking forward to trying that myself!
and WC T5 trans.
'81 G10 Shorty Van
Old 11-12-2011, 10:46 AM   #16
feller
feller's Avatar
heres a pic of the raised roof pods. i had the same questions and am still looking for either a roof section or a compleet cab if anyone knows where i can find one. if you look at the outter two lights youll see the raised pods, and the firemans hats were put on trucks untill 88 or 89 depending on the truck, i think thats right
feller is offline   Reply With Quote
Old 11-12-2011, 12:01 PM   #17
woodwright
Enjoying left field
woodwright's Avatar
Blazerman, do you have any more pics of the clear backup lights? Like maybe on the cab? I've got a 70 with the pods and have been looking for a clear version. What year stepside are these from?
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 11-12-2011, 02:37 PM   #18
BLAZERMAN
BLAZERMAN's Avatar
Clint, next time I'm out in the shop I can snap you a few more pics of them. If you do a search you might find them on a truck on this site...I was thinking it was Longhorn Man that first did this on his truck. They are from 67 to 72 stepsides...they list in the LMC catalog for about 4 bucks each..as for amber lamps check out Ebay, you should be able to find them in LED....thats what I plan on doing with the Yankee 77s
Old 11-12-2011, 02:54 PM   #19
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Talking Re: A couple cab light questions
80340 is the number for the backup lights. Available through NAPA or anyone who handles truck lite. 67-87 Chevy stepsides used this style backup light.
Hope this helps!!
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 11-12-2011, 02:56 PM   #20
Firefighter
They also have an aluminum housing version available, part # 92WD
Yellville, Ar. USA
Old 11-12-2011, 03:02 PM   #21
BLAZERMAN
BLAZERMAN's Avatar
Hope this helps!!
80340 is for the complete assembly and that wont work as a cab light, I couldnt find just the lens on there website but should be available thru any of our board vendors.
Old 11-12-2011, 03:12 PM   #22
Firefighter
99095C is the number for the clear lens.
Yellville, Ar. USA
Old 11-12-2011, 03:21 PM   #23
Firefighter
I wouldn't use it though, it has a notch cut out for water to drain.
Yellville, Ar. USA
Old 04-14-2016, 11:46 PM   #24
drewbert41
drewbert41's Avatar
What size mounting screws are needed for Yankee 77s?
drewbert41 is offline   Reply With Quote
