Alright folks, Any idea how this is done? I always thought that stock hubcaps would never fit corvette/muscle car ralley wheels. The example pick has proven me wrong. Is somebody selling these special caps as ralley wheel compatable or is this someone's trick enginuity to make them work? I'd really like to slap on some stock 57' hub caps to my corvette ralleys.
1957 Chevy Pickup 1/2T, stepside, big window, 77' Camaro subframe, 3rd gen Firebird rearend w/3.23 gears & disc brakes, 66' 283cid, TH350 auto, everything else is original |
![]() Join Date: Oct 2009
Re: 57-59 pickup center caps on corvette ralleys?
dunno but i like it - i hope someone answers this... But it brings up another question - WHY is it that some tire shops can ALWAYS balance a wheel/tire without putting any weights on the outside of the rim - and some NEVER can?
This is what I did.
Byron |
![]() ![]() Join Date: Nov 2008
Not that I have a DEFINITIVE answer - because I haven't done it, but I HAVBE thought of it and I'm guessing that it involves several of THIS little part (middle of page about center), carefully measured for.
Thoughts? http://www.truckandcarshop.com/trucks47_59/t47_100.html |
![]() Join Date: Apr 2009
Im all ears ive got six lug truck rallys on mine. Id love to put stock hubcaps on it.
Posted via Mobile Device |
How did you attach those hubcaps? Great look!
Those caps and rings came from Stockton Wheel in Stockton Ca. http://www.stocktonwheel.com/ They fit great and they stay on. The rims are stock 15 X 8 Corvette ralleys.
Byron |
#8 | |
i think the rally caps and the 58-59 caps are same if not i know they sell metal tabs you can put on the lugs and it has a deal for them to lock in.
1972 gmc jimmy project comin soon ( jus a sin ) ![]() 1959 chevy apache shortbed fleetside (brsgrm) ![]() 1966 Chevy c30 duallie 2wd (big chief) ![]() |
chevy trucks hubcaps are 8 inches wide across inner lip, and the rally cap centers measure 7 inches across
Exactly! I tried to fit a factory 57-59 pickup hubcap on my corvette rally wheels......too big!!! Someone must make an aftermarket pickup cap that fits the rally wheels. I'll keep looking.
hey google the wheelsmith i got a set they put a smaller ring on inside of factory caps A1 people to deal with they can do anything it seams with wheels caps
http://67-72chevytrucks.com/vboard/s...=1#post3961141 |
You just buy the replacement clips fir stick rims from a place like The Truck Shop in Orange, CA, measure carefully, drill for sheet metal screws and there you go. You'll see that's how Delmo mounted early caps to smoothy 20 & 22" Centerlines in a couple of his builds.
#14 | |
Wont work 20 inch centerline wheels are different than rally's
#15 |
I have had this problem before to correct this you need two set of caps (cheapo police rally caps made in china to destroy) and 55-57 Truck caps.
Cut the import cap with large enough cut off wheel on inside edge cap. Then on 56 cap trim edge flat and try to keep as much of material as you can as long as it is flat. Place cheap cap edged that you cut off on 56 Hubcap centered and spot weld. Making sure that you put a wet rag inside the cap to prevent damage to chrome from inside. After spot weld I used liquid nail or JB Weld for cheap insurance. I have done this on 48 Ford hubcaps to aftermarket solids wheels and chevy truck to rally's. What makes it a pain is centering the new cap on old cap use a t_square if you can! ![]() |
#16 |
big guy
![]() Join Date: Jun 2008
#17 | |
Yes they will help they will ask you to send them your hubcaps and modify them as i stated and return them back to you with a fee
#18 |
BIG CHEVY 3600 LONGBOX
Like was said before, use the clips.
If I were given 8 hours to chop down a large tree, I would spend the first 6 hours sharpening my ax. Abraham Lincoln http://s729.photobucket.com/albums/w...cpZZ3QQtppZZ20 |
#19 |
#20 |
Well that's not good news. I bought a set of camaro rally wheels and a set of the Chevy moon hubs and a set of the clips 4 pr 5 years ago with the intent of
using the hubs.
