Old 11-11-2011, 11:27 PM   #1
martindc1
67 K20 Final Drive Ratio...
Sometime in the past there was a bit of a problem with my 67 K20 (250/sm420). There was some kind of failure in the rearend and the seal surface got fouled up. Whoever fixed it used a repair sleeve. They did a pretty good job but there is a constant leak on one side that makes a mess and seems to be getting worse. So today I picked up another HO52, the plan being to switch housings. I'm pretty pleased as I got the axle and an original step bumper in good shape for 100 bucks.
So anyways, the new axle has a 4.11 and the existing ratio is a 4.57. So now I have this idea rolling around in my head to maybe go to the 4.11 ratio. Should I do it? The truck is mostly my camping and hunting rig, so it sees the road a good bit. Maybe some day I will pull a not-very-big camper with it. Tires are 265/75/16s, so say 32 inches and I will never go bigger.
I compared engine RPMs at various road speeds using a gear ratio calculator on the web, and I would save a couple hundred RPMs depending on speed. I suppose this would add up over time.
On the other hand I would have to change the front ratio to match. I have set up a few gear sets before and have the tools, so I'm not worried about that. However, there seems to be several applications of the D44 through the years so I am slightly concerned about finding the right parts. Although I may be able to sniff around on the boards for a used gearset, as a quick search revealed that many think the grass is greener on the other side. What kind of interchangeability is there between front Dana 44s through the years? Since mine is a closed knuckle. How common were the 4.10 ratios in the Dana 44 equipped trucks?
I reckon I could test drive the truck with the 4.11 third member when I switch housings to see if it would be worth it, then switch back to the 4.57 third member if need be.
Also, this new axle came out of a coil spring truck, so I'm assuming things are the same other than the spring perches correct?
Currently truckless, previous trucks:
67 K20, 87 K10 aka V10 & 72 C10
martindc1 is offline   Reply With Quote
Old 11-12-2011, 08:59 PM   #2
martindc1
Re: 67 K20 Final Drive Ratio...
After thinking a little more, if I wanted to go with the 4.11 third member I might be further ahead to find a disk brake equipped 4.10 Dana 44.
Old 11-13-2011, 04:28 AM   #3
1malo68
1malo68's Avatar
You'll get a better turning radius with an open knuckle 44 too!
1968 K10/30
Frame Off Project "Overkill"
My 5 year, $30,000.00 toy
1malo68 is offline   Reply With Quote
Old 11-13-2011, 10:45 PM   #4
lukefalls
Good Luck finding a 4.10 Dana 44. Not many GM unit came that way. There were some 3/4 tons with 4.10, but by far most had 3.73 or 3.08 You can interchange any Dana 44 EXCEPT:
Ford High Pinion (HP)
Jeep HP
Anything HP
Jeep aluminum Dana 44
Late model JK Dana 44
maybe some other odd applications
Just remember that if you find a 4.10 set of gears and decide to use the entire carrier, the side gears may not be the same as what you need. Stay away from the Dana 41 (its a rear only) that looks very similar to the Dana 44
lukefalls is offline   Reply With Quote
Old 11-13-2011, 11:12 PM   #5
martindc1
Are the spring perches the same width on the 73+ D44s? So if I did switch axles and went to disk brakes I would need hoses and a master cylinder, anything else?
Funny thing is I did a quick search for "Dana 44" on a local craigslist and found a 4.10 D44 and 14BFF for sale as a set for $600, but I'm not in a position to buy right now.
Old 11-13-2011, 11:14 PM   #6
lukefalls
Yes, 69-87(91 Blazer/Sub) all have the same spring width in the front. If you find a 3/4 ton rear that is 73+, you'll need to move the spring perches. 1 Tons are the same as 67-72
Old 11-13-2011, 11:34 PM   #7
martindc1
Good info thanks.
Since I have 2 HO52s I probably wouldn't switch to a later axle. If I had to buy I set I'd probably turn around and sell the later rear axle. How does the D44 compare to a 10 bolt strength wise?
How late did the D44 come in the 73+ trucks?
Old 11-13-2011, 11:52 PM   #8
lukefalls
Keep the HO52. They're actually very good. Check out the link:
http://www.pirate4x4.com/forum/showt...highlight=ho52
I can't remember the exact year that the Dana 44 was changed to the GM 10 Bolt. Maybe 76ish?
They definitely look different.
http://coloradok5.com/axleguide.shtml
Strength between the two is similar. Some say the 44 is better. If I recall correctly, later dana 44s have larger wheel bearings and larger axle shafts. Oh, Dana 44 housing are said to be thicker. Its been so long since I cared about Dana 44 stuff that I forgot.
For whats its worth, I never subscribed to the strength issues. There is much more aftermarket support for the Dana 44 and for that it gets my vote. A well built 44, with conservative driving can handle lower gears and big tires. I ran 4.10s and 37 for years on the rocks of the Rubicon (yes, a full size). That being said, you can blow up a Dana 44 with 33" tires if you drive it like you stole it.
A decent set of shafts and good Spicer u-joints will go a very long way. So will routine service.
