Old 11-13-2011, 03:00 PM   #1
pat565
Grant wood wheel?
Are the Grant wheels offered at $170 worth it?
I looking for a wood wheel that looks similar to a factory unit for my 71
Thanks,
Pat
pat565 is offline   Reply With Quote
Old 11-13-2011, 06:03 PM   #2
70cst
70cst's Avatar
Re: Grant wood wheel?
If you like the look...then go for it. Nothing wrong with a "wood" wheel IMHO. Shop around for the best price.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 11-13-2011, 09:38 PM   #3
'68OrangeSunshine
'68OrangeSunshine's Avatar
I don't know if they make a Grant wheel w/ a 17" or 16.5" diameter like the stock '71, and '68 wheels, respectively. When I bought my '71 GMC Jimmy, the PO had installed a Grant wheel with about a 13" diameter. The truck had power steering, but when it went out turning was a b!tch. The other Grant gripes were:
1) Bad horn connection- always honking when not necessary.
2) Continually coming loose from the steering column.
Not until I reinstalled the original wheel did that truck handle right.
Wood wheels do look cool. Mine was wood. IMHO Grant wheels are junk and not worth $1.70. But it's your truck.
Old 11-13-2011, 11:23 PM   #4
05crewcab
05crewcab's Avatar
My truck came with one so I am stuck, but if I had a choice I would not buy another one. The mounting hub is cheap and will strip out if you install/uninstall more than a couple times, and the horn cap and connections are indeed garbage. I'd much rather install a 88-94 c/k wheel. They look nice though...
1971 C-20 350/350
05crewcab is offline   Reply With Quote
Old 11-13-2011, 11:26 PM   #5
1972RedNeck
1972RedNeck's Avatar
What was wrong with the handling with the grant wheel?
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 11-13-2011, 11:45 PM   #6
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
I can testify that you can make almost anything fit. This set up cost me $59 with shipping.
The Grant hub and stuff was extra. All-in, about $115. I forget the brand. But it's an Italian mfg. for marine application.
About 13 1/2"....A little small for some folks. But not silly-small. And, I have P.S.
I just re-drilled the hub and played with the horn stuff a little. This is the only pic I have right now.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 11-14-2011, 12:23 AM   #7
rsavage
rsavage's Avatar
I have two Grant wood wheels both bought new for $50 and $60 respectively- one at a parts meet and one that didn't sell on ebay ( I contacted the seller after the auction ended and took a chance). The installation kits I have also bought off ebay for $15-20. I also had a stock black 73 truck wheel on my shortbed a few years ago. It looked nice but they are flatter than the stock wheel or the Grant wood wheel and consequently, my hand often hit the turn signal lever when turning. I personally like the look of the wood wheel - the special "Corvette option" right?
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 11-14-2011, 02:15 AM   #8
Pont406
Try a local pick a part.Sometimes I find old superior wheels for $5-10.
Pont406 is offline   Reply With Quote
Old 11-14-2011, 02:53 AM   #9
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
heres mine got it off CL for 100 bucks brand new
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 11-14-2011, 04:29 AM   #10
'68OrangeSunshine
Ever see Moe Howard in the "3 Stooges" when the steering wheel comes off in his hand. Great comedy. Not funny in real life. Also it would cock at different angles -- sometimes the "top" would settle at 2 O'clock, sometimes at 11 O'clock. It was never boring, I'll give it that. The pot metal hub sometimes would work loose -- about every 60 days. My pinky would catch the turn signal lever. Horn would go off -- usually at the least appropriate times.
But as to handling... it's kinda hard to put it -- but the "feel" was wrong. I've been driving my '68 Stepside since 1973. I was well used to it. It has a 16.5" stock wheel. Truck was all manual. The GMC had the 12" Grant when I got it in 1995. I had to pay more attention to steering with the woodie wheel. When I put the stock [17"]OEM wheel on, I could pull the wheel around without thinking. The truck went where I "felt" I was pointing it. Also the 17" had a lot more leverage, especially when the P/S was out, like a deadstick -power out condition. And it hasn't come loose since.
