11-13-2011, 06:58 PM | #1 |
Temp problem
I just got a 05 sub with a 5.3. The temp gos way past the 260 mark but it don't seem hot at the motor and it's not boiling over so I replaced the temp sending unit and it still does it can anybody help
Posted via Mobile Device |
11-14-2011, 08:36 PM | #2 |
Re: Temp problem
The stepper motor in the insterment cluster is most likely bad, Easy to check with a scanner that can access the cluster (IPC), If the data stream is reading normal temp the cluster is bad. Rebuild or replace the cluster.
11-15-2011, 10:17 AM | #3 |
Re: Temp problem
ok thanks ill check into that
