11-14-2011, 10:19 PM | #1 |
Intermittent loss of power
I was driving home tonight and the motor and radio would intermittently shut down for just a moment then start right back up. It was like someone pulled the plug on an electric motor then plugged it right back in. I know the motor and radio shut down, but the headlights, dashlights never blinked.
Any ideas?
Willie Swamp Angel Truckers '72 C10 Highlander People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. |
11-15-2011, 12:04 AM | #2 |
Re: Intermittent loss of power
I would start with checking for loose cables from the battery to the starter solenoid. It sounds like you have a loose wire on the ignition circuit. good luck.
Mark 1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20" My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609. My first start up http://youtu.be/R899YQ1OcjU |
11-15-2011, 01:20 AM | #3 |
Well, you are refering to two seperate circuts. The headlamps and dash lamps are on the battery circut (always hot). The engine and radio are on "run" and "accy" circuts. Both of these are switched by the ignition switch. I'd start there and see what everything looks like, the work down from there. Take a look at the schematic if you have one.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
