Old 11-14-2011, 12:53 PM   #1
crazy longhorn
Fabricate till you "puke"
02 silverado,inner tierod ends
I have an 02 1500, 2wd that needs inner tierod ends. The truck has 165,000 on the clock, so my ? is ....Would it be more economical(in the long run), to just replace the rack & pinion assy,vs just replacing the inner tierod ends? crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-14-2011, 04:28 PM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: 02 silverado,inner tierod ends
If you have no leaks, noises or other concerns with your current rack, I would replace the tie rod ends and bellows and call it a day.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 11-14-2011, 10:40 PM   #3
crazy longhorn
Will that require a drill fixture, to remove the pins(like on most front drive apps)? crazyl
Old 11-15-2011, 09:48 AM   #4
usmcchevy
usmcchevy's Avatar
You can use a "inner tie rod removal tool" most auto stores have it as a loan-a-tool. Or a pipe wrench and vise grip have been used.
http://67-72chevytrucks.com/vboard/s...d.php?t=469722
Build thread
LSx Swap FAQ index
Old 11-15-2011, 02:39 PM   #5
crazy longhorn
Many thanks crazyL
