11-15-2011, 11:29 PM | #1 |
headlight connector ?
does anybody know the part number for the pins that go in the headlight plugs? and if so where i could find them.
thanks chris |
11-16-2011, 06:37 AM | #2 |
Re: headlight connector ?
local autoparts store// in the "help" section i've seen pigtails with the complete connector assys for headlights
11-16-2011, 08:47 AM | #3 |
Next time you're at a junkyard pull one. All you need is a little, flat blade screwdriver to depress the tang in the metal wire connector that is inserted in the plastic connector.
On your way home stop by NAPA and purchase a handfull of part number 725147. This is the female, metal connector that is crimped on to the wire then slid into the back of the plastic connector. Buy extra 725147s and keep them on hand. They fit in most connectors in your truck and are handy to have around if you find an issue that needs to be addressed in your wiring.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
11-16-2011, 08:58 AM | #4 |
I would just buy the pigtail or get it at a junkyard. Headlights have a wider spade so a type 56 or normal female spade connector does not fit.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
11-16-2011, 11:16 AM | #5 |
Napa
