Old 11-24-2010, 01:48 AM   #1
rbar
rbar's Avatar
700R4 replacing 3 speed
Hey guys,
I am going to put a 700R4 in my 65. It currently has the 3 speed manual in it. Does anybody know off hand if it will fit under the floor ok since it doesn't have the granny tranny hump? I need to break out the tape measure and crawl around it, but it's only 4 degrees out today. Thanks.
1963 Chevy stepside 327
1965 Chevy swb 383
1996 Mystic Mustang Cobra
2009 Pontiac G8 GXP 415hp/415tq 6speed
rbar is offline   Reply With Quote
Old 11-24-2010, 02:26 AM   #2
sixtyduece
Re: 700R4 replacing 3 speed
yeah it will fit. i have one in my wifes 62
sixtyduece is offline   Reply With Quote
Old 11-24-2010, 10:19 AM   #3
Clyde65
Clyde65's Avatar
Yea it will fit just fine, I have the 4l60e in my 65, which is the younger sister to the 700.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 11-15-2011, 07:42 PM   #4
Touchdown67
Touchdown67's Avatar
Originally Posted by rbar View Post
Hey guys,
Hello... I was just wondering if you did this transmission swap in your 65? I would love to have any information or photos on the swap. Thank you..
Tim....
Touchdown67 is offline   Reply With Quote
Old 11-15-2011, 07:48 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
my 66 had a 700r4 in it, after the 3 speed manual, but before the 4l80e haha
It will definitely fit, as the overall profile of the 700r4 isnt huge. If you haven't worked with the 700r4 before, just make sure you have the TV Bracket mounted onto your carb. Without it the trans will be useless, as the 700 relies on the TV cable for operation...without it it will melt down.
I'd also suggest a good tranny cooler if you don't have one.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 11-16-2011, 11:22 AM   #6
Chevy Fleetside
Chevy Fleetside's Avatar
You will have to bed the cab lip a bit, not much maybe a 1/4 inch. The 700 will hang up on it. I think you can see the lip I am talking about in this picture. I drove this truck for 4 years with a 700R4 in it.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 11-16-2011, 02:32 PM   #7
skysoldier173rd
skysoldier173rd's Avatar
Aside from the TV cable hookup, don't forget this trans has an electronic hookup for the torque converter lockup. You will need to address both issues to get the full benefit of the OD trans.
skysoldier173rd is offline   Reply With Quote
Old 11-16-2011, 11:52 PM   #8
samuellg1977
samuellg1977's Avatar
Hey, Skysoldier, Did you get yours hammered down? Never got an update on the outcome.
Everything above is all good advice. The TV cable adjusts shift points and stiffness of shifts and the electronic part controls the torque convertor lockup. If it doesn't shift correctly or lock up (atomatically or manually), you will DESTROY that tranny. I know from experience. Very expensive lesson learned!! Now, i have a couple of these transmissions lying around for future projects. Get em cheap and rebuild them, then squirrel them away for other rides. I will never go with any other trans than a 700R4 in anything I build from now on.
Sam
samuellg1977 is offline   Reply With Quote
Old 11-17-2011, 12:52 AM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Sam
If you want to put serious power in front of those 700r's, your going to HAVE to keep a few around. At least you'll get good at rebuilding 'em.
Old 11-17-2011, 08:50 AM   #10
skysoldier173rd
Yes, Sam. I ended up putting a manual switch on the dash for torque converter lockup, but i leave it in the "on" position pretty much all the time. I had to play with the adjustment on the tv cable a little, but got it where it needed to be finally. Works like new. If i had it to do again though, i think i would just use the vacum operated switch to operate the converter, really doesen't to seem to be any reason to manually control it when the factory switch did a good job. I've driven the truck everywhere all summer long and no problems. Just put it away for the winter last week. The old gal is resting now till spring and then it will live again.
Old 11-17-2011, 08:58 AM   #11
jason65
Registerd User
jason65's Avatar
I had to do the same thing.
jason65 is offline   Reply With Quote
Old 11-17-2011, 01:11 PM   #12
kieth
kieth's Avatar
Hey guys,
Yes it will fit , I put a tbi 350 with 700r4 in my 66 gmc, here is what I used and it fit just fine.
1. newer style motor mounts from a 91 burb
2. Tubular crossmember
I may have used the forward holes on the motor mounts cannot remember
did not have to massage trans tunnel......Kieth
here is a link to my build and the motor mounts :
http://kieth.smugmug.com/Trucks/66-G...03189742_7VUCY
here is the trans crossmember:
http://kieth.smugmug.com/Trucks/66-G...39504536_X5Lck
kieth is offline   Reply With Quote
Old 11-17-2011, 02:33 PM   #13
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I had a manual switch as well, but I really don't think leaving it ON is the best idea. Deceleration etc while locked up is less than ideal.
Old 11-17-2011, 02:45 PM   #14
skysoldier173rd
I thought that too, but i found the converter automatically disengages upon deceleration as the trans shifts down. It's got several thousand miles on it and no problems whatsoever.
Old 11-17-2011, 02:53 PM   #15
summerj
For $120 you can change out the electronic converter and go with a mechanical that locls up at 1100 RPM. Also get the ceramic pack 3rd and 4th gear.-Much stronger.
summerj is offline   Reply With Quote
Old 11-17-2011, 03:08 PM   #16
skysoldier173rd
I agree, the 700r4 is not a hot rod trans, but I'm pretty easy on it. Got a real low rear from the old granny gears (its original and had the granny geaer with the 4speed) and it'll rip your face off from zero to 60, but also get a nice combination with the OD and it cruises nice.
Old 11-17-2011, 06:05 PM   #17
Chevy Fleetside
I couldn't leave my switch on. My tranny has a reprograming kit in it and locks up in 2nd gear with the switch on. Talk about lugging an engine.
Old 11-17-2011, 08:35 PM   #18
skysoldier173rd
Must be a newer edition. I know there are some variations of the 700r4. There are different wiring patterns. Mine only locks in OD.
Old 11-17-2011, 08:40 PM   #19
samuellg1977
Mine too. If i leave the switch "ON", she bogs to a crawl as soon as it jumps into 2nd gear.
Sam
Old 11-18-2011, 12:07 AM   #20
Chevy Fleetside
Mine is a 88 year model
Old 11-19-2011, 08:10 AM   #21
skysoldier173rd
Sam: Mine bogged to a crawl on the 2nd gear shift too, until i adjusted the TV cable and that extended the shift and took care of the problem. Had to adjust again and again, but finally got it just right.
Old 11-19-2011, 08:14 AM   #22
samuellg1977
Not enough tension to hold off the lock-up, huh? Yeah, I got it sorted out. Now, mine will give you the PEZ-HEAD when it bangs second.
Old 11-30-2011, 09:16 PM   #23
Touchdown67
What about putting a 200R4 instead of the 700R4? Will the 200 fit better?
Old 11-30-2011, 09:26 PM   #24
67swb72klb
67swb72klb's Avatar
the 200 is a smaller trans a little harder to find though gm didnt have them around as long
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 12-15-2011, 12:23 PM   #25
KVB
I have 1965 230 inline 6. Will the 700R4 bolt up to the 6cyl?
Ken
KVB is offline   Reply With Quote
3 speed, 700r4, hump, tranny
