Old 11-18-2011, 11:31 PM   #1
Fan2zee
Fan2zee's Avatar
Oil Pressure Gauge: Installation Help
I'm replacing an aftermarket Oil Pressure Gauge, back with an original. Need help on what goes where.
I've attached pics of AfterMarket v's OEM
Aftermarket has red wire, black wire, oil tube.
OEM: studs...hole????
87' R10
Fan2zee is offline   Reply With Quote
Old 11-18-2011, 11:53 PM   #2
pops45
Junior Member
pops45's Avatar
Re: Oil Pressure Gauge: Installation Help
The OEM just plugs into the cluster back plate like the rest of the gauges. There should be some metal u-shaped pieces that fit through the circuit board and into the square holes behind the gauge.
pops45 is offline   Reply With Quote
Old 11-19-2011, 12:02 AM   #3
Fan2zee
Fan2zee's Avatar
What keeps/holds the oil pressure tube into the oem Gauge? The aftermarket has a nice fitting, with threads, keep tube in place.
87' R10
Old 11-19-2011, 12:14 AM   #4
pops45
Junior Member
pops45's Avatar
No tube. The oem uses an electric sender.
Old 11-19-2011, 12:24 AM   #5
Fan2zee
Fan2zee's Avatar
Okay so red wire, and black wire...am I missing a third wire?
87' R10
Old 11-19-2011, 12:43 AM   #6
pops45
Junior Member
pops45's Avatar
No wires. The black and red on the aftermarket gauge are for the light for the gauge. The oem runs off the circuit board on the back of the cluster.
Pull your temp gauge and you can see how it connects.
Old 11-19-2011, 01:47 AM   #7
Fan2zee
Fan2zee's Avatar
Oh I see. Im missing those clip connectors. Thanks....
87' R10
Old 11-19-2011, 01:59 AM   #8
pops45
Junior Member
pops45's Avatar
Yep you got it. I have extras if you need some.
