Old 11-19-2011, 08:17 PM   #1
Reziel_1983
Reziel_1983's Avatar
Installed new engine today, think that I might have an Exhaust Leak.
Hey guys, I put my 377 in today and when we fired up the engine to do the break in I heard a sort of high pitch ticking type noise coming from what seems to be the passenger's side of the engine. I didn't notice until we had the engine at about 2k rpms but one of the pipes or whatever on the header was red hot. Whenever we were putting the headers back on we accidentally bent one of the gaskets. Could this be an exhaust leak?
1983 Chevy lwb: 400 sbc destroked to 377, comp cams xe 268, Holley Street Dominator Intake, Holley Street Avenger 670 cfm, headers, flowmasters. SOLD
1998 Trans am, mostly stock with magnaflow catback
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=454329
Reziel_1983 is offline   Reply With Quote
Old 11-19-2011, 08:51 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Installed new engine today, think that I might have an Exhaust Leak.
if you bent it you may have cracked it and it simply blew out
another posibility is if you dont have a notched pan the crank on 377's hits the side of the pan for some odd reason
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 11-19-2011, 10:01 PM   #3
Reziel_1983
That could be it too... we just used the stock 400 sbc oil pan that came with the block...
Old 11-19-2011, 10:06 PM   #4
Reziel_1983
Do you have the link of the oil pan I would need? I'm gonna change the header gasket tomorrow to see if it's fixed, but if not I guess I'll order a new pan. But the noise did sound like it was coming from the header.
Old 11-19-2011, 10:27 PM   #5
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
did I understand you to say that one of the eight header tubes was red hot? and the other 7 weren't?
If so I'd be pulling that valve cover too to check everything for that cylinder.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 11-19-2011, 10:42 PM   #6
Reziel_1983
Yes, that's correct, one tube. What should I be checking for when I pull the valve cover?
Old 11-19-2011, 11:11 PM   #7
Reziel_1983
Seems like the spark plug wire for #6 has been burned through. This is the same cylinder that was red hot on the header tube. Put a new gasket on, noise still there... I think you're right about the pan cause it sounds like its coming from the bottom.
Old 11-19-2011, 11:24 PM   #8
Reziel_1983
New wire on, tube still getting red.
Old 11-20-2011, 12:37 AM   #9
68GMCCustom
pull the valve cover....and check your p-rods/rocker arm for proper installation/movement and make sure your intake and exhaust valves are opening all the way.
Kurt -
Old 11-20-2011, 12:49 AM   #10
Reziel_1983
Alright, I will do that tomorrow. Thanks.
Old 11-20-2011, 01:47 AM   #11
stroker87
I had to change oil pans on my 383 stroker dont remember what was hitting it (rod bolt I think) one of the shops tried to bang on it to get the clearance needed since it was just barely hitting it but that didnt work out to good so i installed a moroso #20182 pan worked out well
stroker87 is offline   Reply With Quote
Old 11-20-2011, 02:47 AM   #12
INSIDIOUS '86
you can see dents in the bottom from where the rods made thier own clearance lol
i used hamburgers 1088 oil pan. comes with gasket and pickup, but it wont tell you that on summit
Old 11-20-2011, 09:08 AM   #13
rs72z
rs72z's Avatar
Is this a destroked 400 or is it a std bore 350 with 3.75 400 crank?
rs72z is offline   Reply With Quote
Old 11-20-2011, 10:10 AM   #14
Reziel_1983
Destroked 400.
Old 11-20-2011, 10:27 AM   #15
rs72z
rs72z's Avatar
No need wording about the rods hitting the pan then. Make sure you don't have any vacuum leaks also. Pull the header back off and check the gasket.
Old 11-20-2011, 01:37 PM   #16
INSIDIOUS '86
mine is a destroked 400 as well, maybe you have a valve not closing on the exhaust and that ticking is the combustion exiting the valve into the exhaust causing it to glow
Old 11-20-2011, 01:47 PM   #17
csb#356
Yeah your exhaust valve is probly not closing all the way, and that could burn that valve really quickly.
csb#356 is offline   Reply With Quote
Old 11-20-2011, 03:11 PM   #18
Reziel_1983
Thanks, I will try and figure out if it's not closing and how to make it close if it's not, lol.
Old 11-20-2011, 03:51 PM   #19
68GMCCustom
new motor.....not surprising to have the valve lash adjustment or something else be off somewhere...easy to do.
Kurt -
Old 11-20-2011, 09:21 PM   #20
Reziel_1983
readjusted valves, noise still there. Didn't test the header though because we want to get the noise resolved before that. But there's also a lower pitch kind of knocking sometimes... usually when the engine is revved a little. We don't know for sure but think it could possibly be a main bearing... going to have someone come look at it tomorrow...
Old 11-20-2011, 09:30 PM   #21
INSIDIOUS '86
check the pan near the pan bolts by the flywheel if you see notches that werent there its the rod smacking the pan
idk why mine did considering these motors are shorter stroke so one would think there wouldnt be a clearance issue? oh well i like my hamburgers pan alot lol
Old 11-20-2011, 09:57 PM   #22
Reziel_1983
I'll check that tomorrow. There are two distinct noises though that we're hearing, and then there's the header tube glowing. We think that we're most likely gonna have to pull the engine again...
Old 11-20-2011, 10:00 PM   #23
Reziel_1983
Another weird thing is, the higher pitch noise isn't always there, only sometimes... and whenever we changed the timing, it would sometimes get worse.
Old 11-21-2011, 02:34 PM   #24
INSIDIOUS '86
sounds like something isnt right in the valvetrain, did you use break in oil for the engine?
Old 11-21-2011, 03:16 PM   #25
stroker87
worse cause the idle changes same as revving it up?
