Old 08-25-2003, 08:18 PM   #1
still w.i.p '68
Dreams are free
still w.i.p '68's Avatar
key cylinder replacement questions
I have purchased new door locks, and a new ignition cylinder,
from a fellow board member, (thanks Bill ), and am asking for any tips about replacing them, I know there is a deal with a paper clip, for the ignition, but can't remember how it goes, and I don't recall anyhting on the doors, any help is greatly appreciated..John
'68 swb fleetside
originally w.i.p '68
member since 1-01
w.i.p = ( work in progress )
still w.i.p '68 is offline   Reply With Quote
Old 08-25-2003, 08:22 PM   #2
lukecp
Formerly yellow72custom
lukecp's Avatar
For the ignition:
Put your key in the ignition, the stick a paperclip wire in the hole on the left side of the key hold. Press down on the paperclip and turn the key to the left and pull out all at the same time and it should come right out
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 08-25-2003, 08:25 PM   #3
jcueckert13
jcueckert13's Avatar
for the doors remove the door panels and roll up the window. reach in to the door and behind the lock there is c clip that you need to pull out once you remove the clip you need to unhook the linkage and the lock will come out
jcueckert13 is offline   Reply With Quote
Old 08-25-2003, 08:29 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Yellow forgot to mention the cussing and throwing fits to get that ignition switch out. Jewels will tell you all about that. (sorry Jewels...I had to)
Sometimes they can be a real pain in the 12 bolt. If the key comes out of the switch while you are doing this, something that will hook in the key slot will be needed so you can pull on it.
Some times they just pop out when you do it, other times they really test your paitents.
Old 08-25-2003, 08:33 PM   #5
lukecp
lukecp's Avatar
The last one i did came out in 5 seconds.....but they all arent like that
I need to get a new one for my truck too...you can start it with a screwdriver and pull out the key in the "ON" position, lol
Old 08-25-2003, 08:35 PM   #6
Longhorn Man
That is the ultra rare keyless ignition option.
I think the option code is STEAL-MY-72.
Old 08-25-2003, 09:02 PM   #7
Rod
In a 68-72 you put the key in the acc postion then put the paper clip in... 67 put paper clip in with key in off position.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 08-25-2003, 10:44 PM   #8
still w.i.p '68
Dreams are free
I changed the key switch, very easy!!, thanks
I will wait to tackle the doors wednesday, on my day off..
'68 swb fleetside
member since 1-01
Old 08-25-2003, 11:44 PM   #9
Longhorn Man
Rod, not all 68 trucks had the acc position. I know first hand on Jewels's truck, and another 68 I was looking at last night too. (It's a canadian built truck if it matters)
