Old 08-25-2003, 11:31 PM   #1
jescates
jescates's Avatar
Question Tongue weight on original bumper
Anyone know what an original steel bumper is rated at? This bumper is attached by 4 bolts to the rear of the frame and appears to be original. Doesn't have any stampings on what it can handle.
1970 C-10 LWB
1998 Jeep Wrangled TJ
2009 Honda VTX 1300
2013 Buick Enclave
jescates is offline   Reply With Quote
Old 08-25-2003, 11:42 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Probably 500 pounds...but that would have been 303 years ago.
I'll never tow with one again after ripping one.
And it wasn't so old either.
Old 08-25-2003, 11:51 PM   #3
jescates
jescates's Avatar
Yeah, not sure I want to try pulling anything with that bumper. I have a 55 Willy's that I want to tow a little closer to some prime 4 wheeling locations and even though the Willy's isn't very heavy, I think I might just buy a real hitch. Thanks
1970 C-10 LWB
2009 Honda VTX 1300
2013 Buick Enclave
Old 08-25-2003, 11:56 PM   #4
Longhorn Man
IMO...that is a real good move. I'm one of the few that think a tow bumper should never be used on public roads, and all hitches should be calss 4 or better.
It never fails, you ALWAYS see some idiot with an S-10 using a K-mart step bumper to haul a huge trailer with 2 hummers on it or something else just as stupid.
Old 08-31-2003, 02:02 PM   #5
gmtrucksaddict
400lbs im pretty sure, but it dependson the bumper,
goodluck
gmtrucksaddict is offline   Reply With Quote
Old 08-31-2003, 02:24 PM   #6
jescates
jescates's Avatar
Here's the picture. It's bolted on pretty good, just not sure I would use it to pull the Willy's. The Willy's pretty light but don't want to take a chance of losing it. My problem is finding a hitch that doesn't require relocating the spare tire mount. I kinda like the tire underneath and not in the bed. Looking at the class 3 from JCWhitney. They have one that doesn't require welding, but it doesn't mention the spare tire. Guess I will have to make a call.
1970 C-10 LWB
2009 Honda VTX 1300
2013 Buick Enclave
Old 08-31-2003, 05:51 PM   #7
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I would think that they would be good for 350-lbs of tongue weight, with a 3500-lb towed weight. Hitch receivers, are graded by class, but mine is rated for 500-lbs of tongue weight. Of course, and equalizer hitch would be the way to go, to take some weight off of the rear of the frame. My truck was used to tow a 28--ft travel trailer. My truck: A SWB Fleetside with a 350/400TH set up.
I towed a 55 Chevy 2-dr with a '70 SWB Chevy, that had a 250/3-speed set up. Used the bumper and a ball. All it had was the 4 bolts that hold the bumper on....I hope. That was back in '74.
Member Nr. 2770
Old 08-31-2003, 07:40 PM   #8
Huck
Huck's Avatar
Don't know if they have "Tractor Slupply" stores out there but it is a farm supply type store that sells hitches that bolt right up to our trucks-----the bottom mount spare is not compromised---and the hitch is rated at 6500lbs. I've used one for 4 years with no problems. It even came with the 2" ball!!! Was like $89. All you need is the wiring.
Huck is offline   Reply With Quote
Old 08-31-2003, 08:05 PM   #9
jescates
jescates's Avatar
Thanks Huck, will have to check on that. Here in the desert there is not much call for tractor supplies
I will call back home to Arkansas and see if my dad can find one there. I know of a few places that deals with tractor supplies.
Thanks again.
1970 C-10 LWB
2009 Honda VTX 1300
2013 Buick Enclave
Old 08-31-2003, 10:36 PM   #10
Longhorn Man
Huck, does this look like the one you are talking about?
You can buy them at Tractor Supply Company right here on line.
Old 09-01-2003, 12:50 AM   #11
jescates
jescates's Avatar
Thanks Andy, checked out the site and registered with them. Waiting for a reply from them to see if it's a direct bolt in. If so, consider it purchased.
1970 C-10 LWB
2009 Honda VTX 1300
2013 Buick Enclave
Old 09-01-2003, 03:55 AM   #12
Phillip Johnson
Phillip Johnson's Avatar
I just had one INSTALLED like the one Longhorn posted and it cost me a total of $140. I didnt even get dirty. I can tow anything I own now! I also have torn a factory bumper off a truck. Not fun at all, also not worth loosing what you are towing.
Phillip Johnson is offline   Reply With Quote
Old 09-01-2003, 08:28 AM   #13
Huck
Huck's Avatar
Andy, that looks like the dude I put on my truck. Don't remember if it was a direct bolt in --may have had to drill a hole or two but---it fit the frame perfect. Now I have a leaf spring frame and am not sure what would be required if you have a coil spring truck with the factory overlaod springs---those mounts may need to be removed and then rebolted but it should still come together.
Old 09-01-2003, 01:04 PM   #14
palallin
To buck the trend, I'll say this much for a good step bumper: the receiver hitches bolt to the bottom lip of the frame channel. The bumpers usually bolt through the web (or side) of the "C." If the attachment points are the same in strength (as the are on my bumper), you can tow just as much weight with it. The reason I put a receiver hitch on as well was for the flexibility that the drawbar hitches provide. My 1/4" plate, fully welded and gussetted, overly-engineered bumper can tow more weight that the truck is capable of pulling and MUCH more than it is capable of stopping.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
