Old 11-26-2011, 12:25 PM   #1
Arizona Jim
1963 ChevyPick Up Air Cleaner
Do you know where I can find an after market air cleaner for 292 6 cylinder? I installed a CPP:chevy: power brake booster and dual master cylinder on my 63 PU and the stock air cleaner hits the master cylinder.
Thanks!
Arizona Jim
Arizona Jim is offline   Reply With Quote
Old 11-26-2011, 09:23 PM   #2
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: 1963 ChevyPick Up Air Cleaner
Moved ya out of the projects and builds to the 60-66 section.
Alan's Classic is offline   Reply With Quote
Old 11-26-2011, 11:56 PM   #3
sigshooter
sigshooter's Avatar
Originally Posted by Arizona Jim View Post
Do you know where I can find an after market air cleaner for 292 6 cylinder? I installed a CPP power brake booster and dual master cylinder on my 63 PU and the stock air cleaner hits the master cylinder.
Thanks!
Arizona Jim
Found this picture, looks like what you need..... I suggest searching ebay and the junkyards.
Maybe another member has one like this or can help locate one. I will let ya know if I find anything.
1965 long bed ( grandpas old truck )
1964 long bed BBW Custom Cab
1966 Short stepside
1964 long bed
1965 long bed Custom Cab, factory air, V-8, powerglide
sigshooter is offline   Reply With Quote
Old 11-27-2011, 01:52 AM   #4
cb1965
cb1965's Avatar
i just saw that setup today at the junkyard. had never seen anything like that. i think it was for a rochester 2 barrel carb. i think it was on a 70's chevy truck
'66 chevy lwb c10
'65 chevy lwb c20
cb1965 is offline   Reply With Quote
Old 11-27-2011, 03:45 AM   #5
sigshooter
sigshooter's Avatar
this one looks like a one barrel, but one barrel and two barrel should have the same neck opening
1966 Short stepside
1964 long bed
Old 11-27-2011, 09:27 AM   #6
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: 1963 ChevyPick Up Air Cleaner
Clifford Performance
http://www.cliffordperformance.net/M...gory_Code=C250
Langdon's Stovebolt Engine Co.
http://stoveboltengineco.com/index.p...=0&sort=normal
Advance Auto parts
www.advanceautoparts.com
Autozone
www.autozone.com
O'Reilly Auto Parts
www.oreillyauto.com
Tricked-out Chevy six cylinder engines
http://67-72chevytrucks.com/vboard/s...d.php?t=276823
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 11-27-2011, 10:35 AM   #7
Oldgearz
Oldgearz's Avatar
I have the original oil bath air cleaner off my 62 GMC 305 v6 2bbl, I believe it would fit fine and I'm local. You're welcome to try it out.
1962 GMC 1/2 ton stepside longbed, 305 V6, Muncie 3spd HD tranny, stock rear end, rolling resto!
Oldgearz is offline   Reply With Quote
Old 11-27-2011, 01:21 PM   #8
cb1965
cb1965's Avatar
you know it might have been a one barrel. i just took a quick glance at it so im not sure
'66 chevy lwb c10
'65 chevy lwb c20
Old 11-28-2011, 10:27 AM   #9
1963c-10
1963c-10's Avatar
Those air cleaners could be found on alot of vans also
1964 Short bed trailer
1963 c10, 6 clylinder, aftermarket air cleaner, air cleaner, chevy 292
