Old 11-26-2011, 05:49 PM   #1
Goinlow64
Rear discs install question
Hey everybody,
I just finished up installing new discs in the rear of my 64 swb. However, getting the calipers with pads on the rotors was a mess. The pads are so close, the rotors won't spin now. It is like the pads that came with the setup are just a little too thick. Has anyone else had this happen to them when installing discs? Also, any suggestions on how to get sme play? Thanks guys!
Goinlow64 is offline   Reply With Quote
Old 11-26-2011, 05:58 PM   #2
c10hevy
c10hevy's Avatar
Re: Rear discs install question
What I've always done is use the old pads and a c clamp to depress the piston. On the old ones When the pad wears down, the piston has to extend further to make up the slack. The c clamp method resets the piston and allows you to put in new full size pads.
c10hevy is offline   Reply With Quote
Old 11-26-2011, 06:01 PM   #3
Goinlow64
I tried a c clamp, but the piston seemed to be all the way in. It is a brand new caliper and brand new pads...
Old 11-26-2011, 06:17 PM   #4
65 on 24s
65 on 24s's Avatar
Could have the rotors turned
65 on 24s is offline   Reply With Quote
Old 11-26-2011, 06:22 PM   #5
Goinlow64
What would be the advantage of turning the rotors vs shaving a little off the brake pads? The rotors are brand new
Thanks!
Old 11-26-2011, 06:30 PM   #6
bama63
bama63's Avatar
what calipers are you using
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 11-26-2011, 06:38 PM   #7
Goinlow64
http://www.ebay.com/itm/63-70-chevy-...5#ht_500wt_922
This is the kit I bought off eBay. They are gm calipers, but I am not sure specifics on them. In should also say it is just a rolling chassis at this point, no engine.
Old 11-26-2011, 06:43 PM   #8
shawno72
C/10 junkie
shawno72's Avatar
According to the link that you posted it looks like those calipers are going to need what we call a "caliper retraction". That means that the calipers pistons are going to need to be "screwed" in. Anotherwords you can't just press in the caliper piston with a c clamp you will have to turn the piston clockwise, for most cars, at the same time you compress it in.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 11-26-2011, 06:47 PM   #9
Goinlow64
I guess that is why they call it a learning process. Can you give me some kore details on how I would get it compressed/ turn the piston? It appears the piston is all the way in right now. It is flush with the caliper and does not dtick out any really. Thanks a bunch!!!!!
Old 11-26-2011, 06:58 PM   #10
shawno72
C/10 junkie
shawno72's Avatar
Go down to your local Autozone or Oreillys and rent the tool for it. It should look something like this. What you do is line up the two little notches on the tool with the notches on the caliper piston and then just turn it in.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 11-26-2011, 07:07 PM   #11
Goinlow64
[QUOTE=shawno72;5032083]Go down to your local Autozone or Oreillys and rent the tool for it. It should look something like this. What you do is line up the two little notches on the tool with the notches on the caliper piston and then just turn it in.
Awesome! thanks for your advice!
Old 11-26-2011, 07:10 PM   #12
65 on 24s
65 on 24s's Avatar
Guess it would be about the same idea
Old 11-26-2011, 07:21 PM   #13
shawno72
C/10 junkie
shawno72's Avatar
Your welcome hope it all works out. You might want to look at your caliper pistons to make sure we are headed down the right path. Let me know how it turns out.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 11-27-2011, 02:00 PM   #14
shawno72
C/10 junkie
shawno72's Avatar
Well did it work??
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 11-27-2011, 03:16 PM   #15
Goinlow64
Well did it work??
I wish I had better news. The pistons were all the way in. I used the bench grinder on one pad and shave just a little off and helped a lot. I guess I will do that to the other side and have pretty tight brakes for a while....
Old 11-27-2011, 04:41 PM   #16
shawno72
C/10 junkie
shawno72's Avatar
Ok so my next question is, did you make sure and line up the notches in the pads with the notches on the pistons? You may have to back out the pistons a little to get them to line up.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 11-27-2011, 04:45 PM   #17
Goinlow64
Yep. Did that too. I went the less expensive route and bought my set up on eBay. I think it is probably a more generic setup and I am thinking that is why I am fighting a little bit. I got the front discs from the same seller and they were tight, but they at least rotate! Would it be bad thing to shave the pads a touch? Thanks again for all your help Shawn!!
Old 11-27-2011, 06:27 PM   #18
shawno72
C/10 junkie
shawno72's Avatar
No it won't be a bad thing to shave the pads down a bit, just watch that you keep the surface flat and don't leave grooves.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 11-27-2011, 07:36 PM   #19
65 on 24s
65 on 24s's Avatar
Post some pics of it
