Old 11-26-2011, 11:14 PM   #1
SRVBLUES64
power steering set up
this is for my 66 chevy truck with a 350 motor any thoughts?
SRVBLUES64 is offline   Reply With Quote
Old 11-26-2011, 11:57 PM   #2
samuellg1977
samuellg1977's Avatar
Re: power steering set up
Same style I got in my 63 w/ 350/700R4... What are your questions?
samuellg1977 is offline   Reply With Quote
Old 11-27-2011, 02:03 AM   #3
Captainfab
60-66 Nut
When I sent that to you, all the pieces were assembled how they fit together. All you had to do was bolt it to your pump, install the pulley and bolt it to your engine. I was thinking there was a couple pics of this style in your previous thread on power steering pumps.
Old 11-27-2011, 05:21 AM   #4
SRVBLUES64
I know it was all together but the bracket wont fit on the pump or line up with the holes on the engine
Old 11-27-2011, 05:51 AM   #5
losthope
losthope's Avatar
could you post a picture how it was when it was together?
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 11-27-2011, 06:43 AM   #6
losthope
losthope's Avatar
are you saying it wont bolt to the pump because the pump has that raised portion by the bolt holes and the bracket metal is not cut right to go around the raised part on pump? i think you just bolt it right on top of that raised part....but i would wait for captain fab to reply he seems to be the power steering guru....and that bracket should bolt to the block just fine tho.
heres what i think it should do:
Timmy D.
Old 11-27-2011, 12:36 PM   #7
samuellg1977
The adjuster bracket isn't going to work with the header bolt on the front of the #1 Cylinder. You need a factory bolt that holds the exhaust manifold and a shim to cover gap from the header flange to the adjuster. Other than that, it should bolt right up.
Sam
Old 11-27-2011, 03:56 PM   #8
losthope
losthope's Avatar
Originally Posted by samuellg1977 View Post
the adjuster bracket isn't going to work with the header bolt on the front of the #1 cylinder. You need a factory bolt that holds the exhaust manifold and a shim to cover gap from the header flange to the adjuster. Other than that, it should bolt right up.
Sam
oo
Timmy D.
Old 11-27-2011, 03:57 PM   #9
losthope
losthope's Avatar
Sam
this is what i did!
Timmy D.
