Old 11-27-2011, 02:33 PM   #1
gotchamel
Cutting holes in dash bezel?
Seems like the dash bezels would crack easily, would a hole saw be the preferred tool in cutting more gauge holes?Thanks.
gotchamel is offline   Reply With Quote
Old 11-27-2011, 03:33 PM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Cutting holes in dash bezel?
I cut some holes in my old bezel for guages, used a hole saw
all was well except 1 hole toward th edge alreayd had a small crack, it just made it worse ...
John
1999 Toyota Tacoma 4x4
Old 11-27-2011, 03:56 PM   #3
gotchamel
Thanks, it will be a new bezel so I won't have to deal with an existing crack.
Old 11-27-2011, 06:45 PM   #4
hugger6933
if you can use a slower speed on the drill that will keep it from heating the plastic too much
hugger6933 is offline   Reply With Quote
Old 11-27-2011, 06:50 PM   #5
I recently dried a hole for a factory manual choke cable under the wiper switch on my '71 Custom/30 tow truck using a paddle bit and it went just fine. A hole saw would be even better.
Old 11-27-2011, 09:04 PM   #6
TripleNickel
TripleNickel's Avatar
I wonder if the tip from the "This Old House" show a few weeks ago might help.
They needed to cut through aluminum siding to install a vent and one of the 'guru' used a hole saw... but had the drill running in REVERSE to minimize the chance of tear-out.
TripleNickel is offline   Reply With Quote
Old 11-28-2011, 08:39 AM   #7
That's a pretty good tip to play it safe,but certainly not necessary,especially here. .019-.024 aluminum siding is thin material and metal,which can bend if snagged. Cutting plastic is handled the same as wood in most cases. And,the teeth on a hole saw are identical to those on a circular saw plywood blade,which is what I used,frontwards,to cut thousands of squares of aluminum siding with no issues. People would turn a crosscut blade backwards to cut aluminum siding when all they had to do is use the right blade.
