Old 11-28-2011, 12:18 AM   #1
Project77
L.E.D. dome light conversion kit
has anyone ever put l.e.d. dome lights in their trucks? if so how did you do it and how does it look?
my truck has been completely striped of a dome light and wiring im in need of one and want it to look legit and modern please help me
i found a little something but im not to sure on how i would modify it to work in my truck
http://www.stylintrucks.com/parts/un...0146_5762.aspx
Project77 is offline   Reply With Quote
Old 11-28-2011, 01:41 PM   #2
von guido
von guido's Avatar
Re: L.E.D. dome light conversion kit
i got one in my 78 and its bright!! at least 5x brighter than standard and has a pure white almost blue tinge to it
officer,we weren't racing.. he was merely pacing me.
von guido is offline   Reply With Quote
Old 11-28-2011, 01:49 PM   #3
john_p
you can convert any dome to led pretty easy.. 3 or 4 leds and a resistor .. radio shack has the parts, ebay has them cheaper.. if you have one that is to bright, solder in a 200 ohm resistor and cool it off some.. good leds cost under a quarter, same with resistors.. lot of how to help on line.. i'll be any help can
john_p is offline   Reply With Quote
Old 11-28-2011, 02:37 PM   #4
Project77
lmc sells one but would it go right on with factory wiring? where can i get the wiring harness and wiring diagram?
Old 11-28-2011, 02:41 PM   #5
john_p
i would put it on the original wires.. your not drawing enough current to heat up the wires...
Old 11-28-2011, 03:47 PM   #6
Pop's C-10
Pop's C-10's Avatar
most come with a adapter that goes in tha factory bulb spot & you plug tha led into it..
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 11-28-2011, 04:38 PM   #7
VH Coachworks
VH Coachworks's Avatar
You can readily buy drop in LED bulbs. NO need to buy resisters, and solder your own LED's together. The LED's you can buy at RadioShack are glass dome LED's and not the much newer SMD LED's. The glass dome LED's are dim compared to the SMD's. The old stock bulbs will look completely DIM compared to a good LED in there.
VH Coachworks is offline   Reply With Quote
Old 11-28-2011, 10:28 PM   #8
Project77
can you put a bright led in the cargo lamp? because that doesnt work either on my truck
Old 11-28-2011, 10:31 PM   #9
VH Coachworks
Yes, do you know the bulb number for the cargo lamp bulb?
Old 11-28-2011, 11:07 PM   #10
Project77
what do you mean?
Old 11-29-2011, 12:22 AM   #11
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
www.v-leds.com is where I got all my L.E.D.'s and my H.I.D.'s for my Suburban. My dome lights were a part # 211-2 for both the front and the rear like this...
And this is what i replaced them with from v-leds.com 2 up front and one in the back,
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 11-29-2011, 11:40 AM   #12
rayfinseats
Those $8 Walmart dome lights are really bright. Thats what i used.
rayfinseats is offline   Reply With Quote
Old 09-30-2013, 11:10 PM   #13
mrpaintstick
mrpaintstick's Avatar
what is the bulb # for the exterior cargo lamp for a 76
5 out of 4 people have trouble with fractions
mrpaintstick is offline   Reply With Quote
Old 10-01-2013, 04:27 PM   #14
BONUSCAB
I picked up a drop in LEd replacement from superbrightleds.com when I placed an order for LED's for my dash. It's nice, not stupid bright, but bright. I will be getting a new clear lens with my next LMC order. For my cargo light I picked up this eight inch strip of eight LEDs at Big Chain auto parts. It's cool, you can (and I did) cut it into two four inch strips. I did this and hard wired them in because my bulb socket was effed up. That worked very well.
I picked up some super cheap red 1157 LED bulbs off eBay for my tail lamps. They were total junk. Crumbled apart in my hands just trying to overcome the spring pressure of the socket. Superbrightleds.com isn't the cheapest around, but they sell a great product and they will get my business again.
Few things in life will make you look stupider than putting a dollar sign after a number.
BONUSCAB is offline   Reply With Quote
Old 02-18-2015, 04:31 PM   #15
das601
das601's Avatar
Bonuscab,
Could you explain in more detail how you can cut the led strips and wire them up? I think that is my plan too.
1971 GMC 4x4 4 speed Project
das601 is offline   Reply With Quote
Old 02-18-2015, 07:48 PM   #16
324matt
324matt's Avatar
I used superbright LED's also. Great products. I thought they were reasonably priced vs other stores.
1985 GMC K2500. 350/TH400/208. 4:10's. stock.
1987 Chevy V30. 454/TH400/205 4:10's. Stock SOLD.
324matt is offline   Reply With Quote
Old 02-19-2015, 11:03 AM   #17
SCOTI
SCOTI's Avatar
I looked for a direct replacement style panel like in the pic above (post #11) but couldn't find any. I used some small square panels & fabbed my set-up....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-19-2015, 01:48 PM   #18
TKCR
TKCR's Avatar
I replaced all my lighting with LED and also replaced the light housing & lens. I got everything from LMC. The courtesy lights, I just added a set from LMC and added it to the one presently there, which gave me 3 lights. None of my lights worked either when I got the truck. The door switch terminals were rusted and no longer were attached, so I replaced those also and once I reattached the wiring, the light now work.
As far as the Cargo light, once I replaced the housing, it worked. The housing was all rusty on the inside, so the bulb wasn't making good contact.
