Old 11-28-2011, 12:37 AM   #1
c-tenkid
not new to the board or trucks.But new to 4wd
I own a 69 chevy c-10 lwb truck.Good shape and a great old truck to cruise around town or down the backroads.
But two sundays ago I came across a 69 chevy K-10 truck with a 4inch suspension lift.I bought it.Tore the old body off the 4wd chasiss cleaned it up and than today took my 2wd body and set it on the 4wd frame.
What I am needing to know is if there is special body mounts needed to put a 2wd body on 4wd frame.
Thanks.Try to get some pics up after I wash her.
69 c-10 lwb,Converted to 4x4,dana 44f,12blt,4 inch lift,vortec headed 355,th350/np203 34x10.50x15 swamper tsl's
c-tenkid is offline   Reply With Quote
Old 11-29-2011, 12:24 AM   #2
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Re: not new to the board or trucks.But new to 4wd
Nope, its all the same mounts.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 11-29-2011, 12:01 PM   #3
Your41Plague12
Your41Plague12's Avatar
Body mounts are all the same. Swap the tranny tunnel and you should be good to go!
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 11-29-2011, 04:03 PM   #4
Gene
Gene's Avatar
I thought 2wd mounts were different? Seems like 4wd and 3/4 ton 2wd are the same?
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 11-29-2011, 07:45 PM   #5
c-tenkid
Thanks for the replies guys.The problem I am having is the driver side rear cab corner is about 2 inches lower than the bed.The passenger side is fine.But the driver side is outta wack.
I looked on ECE's website and noticed that there is a 4wd body mount set and 2wd.As well as differences between 1/2 ton and 3/4 ton.
I am going to call ECE this week and talk to them about it.the
Nothing on the frame appears bent or tweaked.And the body I took off sat well on the frame.
By the time I get home from work I got about a half hour before its dark and the truck is outside.So not alot of time to work on it during the week.
Thanks again for the help.Hopefully there is a simply solution!
Old 11-29-2011, 07:52 PM   #6
msgross
msgross's Avatar
LMC truck has the proper rubber mounts...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
