Old 11-29-2011, 09:20 AM   #1
Low Elco
Is there a step by step for 73-87 rockers?
Is there a step by step for 73-87 rockers? I've done a couple 67-72, but I have some questions on my 87, which needs rockers and cab corners. I've been rooting around, but havent come up with anything. Any help is appreciated. TIA, Chip.
Low Elco is offline   Reply With Quote
Old 11-29-2011, 12:03 PM   #2
Desert1957
Desert1957's Avatar
Re: Is there a step by step for 73-87 rockers?
This is a good one....
http://forum.73-87chevytrucks.com/sm...p?topic=5661.0
Desert
Desert1957 is offline   Reply With Quote
Old 11-29-2011, 12:07 PM   #3
Low Elco
Thanks for the lead, hope I can figure it out. Worst come to worse, I'll just bust out the zip wheel and get ta whackin'!
Old 11-29-2011, 03:18 PM   #4
njlimbaugh
Only thing I might add to the build shown, first thing I do is either bolt in or tack weld a brace from one door post to the other which helps hold things where they were before the rockers were cut out. Also, instead of overlapping the joints I make small steel tabs to bridge between the old/new sheet metal and mount them under the sheet metal with 1/8 inch pop rivets. That way the weld is a butt and gets the new metal exactly lined up with the old instead of the overlap. Then I blow out the rivets with the torch and weld up the holes. (I weld with gas rig.)
njlimbaugh is offline   Reply With Quote
