Old 11-29-2011, 10:40 PM   #1
ADub
Brake Flex Lines
I have a bare frame I am putting together. Its a 68 frame and currently has drop spindles. I am getting ready to run the brake lines. I know if I had spindles/discs on the complete 68, I would need conversion brake lines to adapt disc calipers to drum hard lines. Since I don't have any hard lines on the frame yet, do I still need a conversion hose or can I use a shelf part?
69 C10 SWB LY6 T56
70 Chevelle SS 396 4spd
ADub is offline   Reply With Quote
Old 11-30-2011, 10:43 AM   #2
ADub
Re: Brake Flex Lines
bump..
69 C10 SWB LY6 T56
Old 12-05-2011, 05:04 PM   #3
ADub
How about this. My 69 drum brake truck uses 1/4" hard lines to the flex lines. Is this the same on a disc brake truck or do they use different sized lines?
69 C10 SWB LY6 T56
Old 12-06-2011, 03:29 PM   #4
jbice70gmc
jbice70gmc's Avatar
I'm not really sure on this. I am doing disc/disc for the first time to, so as soon as I can get a answer I will post it up. I beleive they are the same size though.
1969 GMC SWB Fleetside
http://67-72chevytrucks.com/vboard/s...d.php?t=486320
jbice70gmc is offline   Reply With Quote
Old 12-06-2011, 07:10 PM   #5
rob32472
Use stock 71 72 brake hoses and your hard lines should work
rob32472 is offline   Reply With Quote
Old 12-07-2011, 06:44 PM   #6
68 short step
drum brakes =1/4" hardlines
disc setup = 3/16 hardlines
68 short step is offline   Reply With Quote
Old 12-08-2011, 12:17 PM   #7
ADub
I was in SoCal yesterday and went to CPP. I learned that in addition to the hard line sizes 68 short step mentioned, the factory flex lines on the disc brake trucks had two different fitting sizes. They were able to pull a pair of flex lines that both had the same fitting size and were the same fitting size as the prop valve, so I can run new hard lines and everything will match!
69 C10 SWB LY6 T56
Old 12-08-2011, 05:34 PM   #8
jbice70gmc
jbice70gmc's Avatar
Good to know. I'm about to start running brake line as well. But I will have to call CPP I'm still here in Htown.
Old 12-08-2011, 06:45 PM   #9
cdowns
cdowns's Avatar
brake hoses depend on what type of brake caliper is used as bango fittings r different for different calipers
Old 12-09-2011, 09:40 PM   #10
ADub
They set me up with kit BHK-R10. It comes with 3/8 banjo bolts, so they gave me a pair of 7/16 banjos to fit my calipers. These hoses are set up to accept 3/16 hard line. They fit up great
69 C10 SWB LY6 T56
