11-30-2011, 06:24 PM | #1 |
srw to drw spindle & brake ?
Ok guys time for some info.
I started to swap my srw 1 ton or so i thought over to drw today. The question i have is did all of the drw spindles use the calipers that use one bolt and the slide on the bottom? Mine has the two bolts like half tons do. So is my truck not a 1 ton? When i put the rotor on it fits but you can't put the calipers on with the pads. Time for a spindle swap? Thanks Paul |
11-30-2011, 07:55 PM | #2 |
Re: srw to drw spindle & brake ?
The single wheel trucks have calipers like a 1/2 ton, with a larger bore piston. The dual wheel uses the large caliper with the retaining pin, as do all 1 ton 4×4's.
1949 Five Window, 1973 Step Side, 2000 Z71 |
11-30-2011, 08:32 PM | #3 |
11-30-2011, 11:43 PM | #4 |
If the caliper doesn't fit over the rotor with the pads in place you will have to replace the spindle for a dually spindle.
12-01-2011, 12:43 AM | #5 |
the dually spindle and the srw spindle are the same right down to the part number thats in the casting with out looking at a picture it almost sounds like you have a 3/4t spindle and the only diferance in the 3/4 and 1t spindls is the way the caliper mounts
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG |
12-01-2011, 08:29 AM | #6 |
I'll get a picture later. When the rotor is on it almost touches the caliper mount, so it is probably a 3/4 ton.
12-01-2011, 08:57 AM | #7 |
So i decided to check the vin on my truck. It's turns out to be a 3/4 ton.
The vin tag says it's a camper special 8200 gvw. So now i get to change the spindels also. Will the 14 bolt rear pose any problems for the drw swap, besides needing spacers? |
12-01-2011, 09:10 AM | #8 |
I have some stock 1-ton spindles.
12-01-2011, 09:12 AM | #9 |
Thanks Scot
I have a set just have to pull them off. Posted via Mobile Device |
