Old 12-02-2011, 12:46 AM   #51
savatreatabvr
savatreatabvr's Avatar
Re: Riddle me this Mechanic Man?
Yeah, I thought that cylinder with the tight valves would have been a big issue once I adjusted them correctly but not the case, the cylinder I have problems with is #4, that one fouls plugs, has 90lbs comp. and has oil on the threads and outside of the spark plug hole.
Originally Posted by raws67 View Post
No Problem!
Ive used this methood before and it was right on the money with a valve problem I had. One other thing that makes me interested is how tight that valve was that you were talking about. That almost sounds like the valve sunk in to the head or a po who didnt know what they were doing over adjusted. Either way you did say that that cylinder seems to run fine. Let us know what you come up with.
savatreatabvr is offline   Reply With Quote
Old 12-02-2011, 12:48 AM   #52
savatreatabvr
No Problem!
Old 12-02-2011, 08:22 AM   #53
rs72z
rs72z's Avatar
What's the rest of the cylinders have for compression? 90 is a little low imo.
rs72z is offline   Reply With Quote
Old 12-02-2011, 08:59 AM   #54
savatreatabvr
The other ones are about 110 to 120lbs.
Old 12-02-2011, 09:02 AM   #55
rs72z
rs72z's Avatar
I know its been mentioned but you need yo do
Leak down in it.
Old 12-02-2011, 01:05 PM   #56
BMERDOC
BMERDOC's Avatar
Using the 15% rule for a compression test and considering you highest reading was 120 then you lowest reading should be around 102. You still need to further diagnose the improper sealing. Rings or valve not seating properly because of worn guides?
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 12-02-2011, 04:55 PM   #57
csb#356
I always learned that it was 10% but either way thats a little low. And no hydraulic lifters are adjusted one time when the engine is assembled and thats it. If they have too much lash, valvetrain compenents are worn. You could tighten the nut down again and take the lash back out I guess but then your just covering up other problems.
csb#356 is offline   Reply With Quote
Old 12-02-2011, 07:37 PM   #58
savatreatabvr
You're right but the reason I adjusted them in the first place was not because the rocker arms were tapping, it was to see if I could get it to stop smoking and run better which it did but #4 cylinder still fouls plugs so I betting on the valve seals being the problem. I replaced the valve seals with the head still on the engine on a Ford Bronco I had, it smoked worse than my BBC but the Bronco never fouled plugs so that's why I was thinking my BBC had other issues.
