12-02-2011, 02:14 AM | #76 |
60-66 Nut
Re: Suburban rear seats and tracks, any info?
If I remember correctly, a standard 5/16" step bolt will work to anchor the seats, in a Suburban that has the fixed anchor plates.
12-02-2011, 02:42 AM | #77 |
12-02-2011, 08:02 AM | #78 |
Check The Champ, Demonstrator
Step Bolt. You can see the difference from a carriage bolt.
Thank you once again Captainfab |
12-03-2011, 12:46 AM | #79 |
60-66 Nut
No problem......
01-10-2012, 12:56 PM | #80 | |
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3 |
05-23-2012, 05:01 PM | #81 | |
By rondavid at 2012-05-23 ron Last edited by padresag; 05-23-2012 at 05:02 PM. Reason: helps when you ad the picture |
05-23-2012, 06:38 PM | #82 |
May as well add my .02 cents worth!
I have the following: 62 GMC ----- 3 seat 65 GMC ----- 2 seat 65 Chev ----- 3 seat 65 Chev ----- 3 seat 66 Chev ----- 2 seat All have "keyhole" fittings in floor for all rear seats. ;-) Posted via Mobile Device
Remember: "When seconds count, the Police are only minutes away". Thx, Billy B. |
05-23-2012, 06:42 PM | #83 |
Forgot something! Looked at a 63 GMC 3 seated last weekend. It also had "keyhole" fittings for all rear seats ---- none had tracks...
05-23-2012, 06:59 PM | #84 | |
ron |
05-23-2012, 11:43 PM | #85 |
Hollister, CA.
My buddy here in town (prerunnerob - he hasnt been on in a long time) has a 66 GMC with tracks...
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
07-21-2012, 12:34 AM | #86 |
Rollin' Old Skool
hey guys, was looking at Tony's site for something else yesterday and noticed he carries some of the seat mounting stuff:
http://www.4-5-6chevytrucks.com/new-parts.html
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
07-21-2012, 01:28 AM | #87 |
Exactly why I'm replacing the seats in my 63.
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
07-21-2012, 08:23 AM | #88 | |
Hollister, CA.
No my friend, my 62 GMC is WELL USED !!!! - -
04-22-2013, 03:05 PM | #89 |
Hollister, CA.
OK, I found out something on my '62 GMC Burban ... not sure if this has been addressed or not.
My Burban uses the bolt in style into flanges, (not rails) Although, the holes are different as compared to the 66 Chevy Burb seats I have .... - - The following pictures are from the REAR (LARGE) SEAT FRAMES for comparison.... NOTE: The older fawn/rusty color is from my 62 GMC , and the lighter color is from the 66 Chevy: - - - - - - - - - As you can see, the lower portion of seat frame is constructed different, and the mounting points in different spots.... - - - - - - - - - - -
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" Last edited by ChiefRocka; 04-22-2013 at 03:11 PM. |
04-22-2013, 03:18 PM | #90 |
Hollister, CA.
Now the MIDDLE SEAT is off a bit too, but not as bad.
Only TWO holes are off in this case, and the tubing runs from LEFT to RIGHT so it will be just a matter of drilling two new holes in the seat frame. - Passenger side holes line up: - - - - Screwdriver marks the floor mount, and area where a hole needs to be drilled in seat frame... - - Front of frame is the same... - - I ended up swapping the cushions from the 66 Chevy onto the 62 GMC frame for the rear seat .... PERFECT !! - - Drill tow holes in middle seat, and I am good ! - - Thats my story, and I'm sticking to it !! - -
04-22-2013, 10:13 PM | #91 |
Just here to tinker
Hey John,
It seems there was no rhyme nor reason for these seat configurations. Here are the middle and back seat to my '60 GMC. Different yet again.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
04-23-2013, 10:31 AM | #92 |
Hollister, CA.
So does this mean 63 and up (like the chassis) is common ?
And we are the oddballs ? Posted via Mobile Device
10-29-2014, 09:00 PM | #93 |
I sure would like to know where I could find a set of those.
"It ain't as easy as Chip Foose makes it look" |
10-30-2014, 12:49 AM | #94 |
the tracks work the same as the cleats I.E. that they use a carriage bolt type mount but the benefit is you can slide the seat forwards and back reverse it ect. The tracks work like the tie downs in a toy hauler. I have a 64 GMC with the tracks, unfortunately my seat is out of Chevy and the rails don't line up with the tracks.
11-06-2014, 04:07 PM | #95 |
Pic of a 63 GMC with rear rails for adjustable positions
GOD BLESS AMERICA! |
11-30-2014, 09:44 AM | #96 |
Music man if you still have this burb can you post some pics of the roof rack?
1961 Apache 10 with side trim 1964 4 door crew cab C20 1966 Chevy Suburban with custom trim 1961 K30 with a 4-53T Detroit diesel 1966 GMC 4X4 Suburban |
10-28-2015, 03:48 PM | #97 |
Good Info
1961 Biscayne http://67-72chevytrucks.com/vboard/s...90#post6978790 SOLD 1971 C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=656258SOLD 1966 Suburban http://67-72chevytrucks.com/vboard/s...85#post7323885 |
