12-02-2011, 12:27 PM | #101 |
Still Learning
Re: 68 aka "Chained in Porterbuilt Prison"
Very interested in watching how you are gonna use that sweet floor shifter!
12-02-2011, 07:21 PM | #102 | |
http://www.ebay.com/itm/330577808927...84.m1423.l2649 But the six speed shifter plate has a rubber boot in the round area U see in the plate above--I think would be totally cooler using the 6 speed boot and the auto shifter rather than the kind of MECHANICAL LOOKING plate above--Make every one go--"Is it 6 sp or auto"??? The console is in pics in post 45...here is a pic of complete with 6 spd shifter but ot a real good pic of plate........jim http://www.ebay.com/itm/03-06-CHEVY-...item3f013f9ea2
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791 |
12-03-2011, 01:54 AM | #103 |
Junk Yartist
Agree. The six speed boot looks way better, and less "late 90's early 2000's" design.
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
12-05-2011, 07:49 PM | #104 |
CCTek
Jim,
I can't believe I didn't see this over here! Awesome work man! I love the dash. I agree with you, the stock dash is what I like least about these trucks. The stock one was cut out of ours long ago! I'm subscribed. Keep it coming! Posted via Mobile Device
Chad 68 swb Project http://67-72chevytrucks.com/vboard/s...d.php?t=262840 72 swb Project SOLD http://67-72chevytrucks.com/vboard/s...=1#post3993641 THANKS TO: Hermance Design (www.hermancedesign.com), Paradise Road Rod & Custom, Harry Opfer Welding, Tri-State Machine, Wegner Automotive Research, Nsane Hotrodz (www.nsanehotrodz.com), Clayton Machine Works, CCTek (http://www.candctek.com) |
12-05-2011, 08:00 PM | #105 |
I'll let the cat of the bag-sort of----Instead of shaved handles-think of Ring Brothers Gen 1 handles !!!!!!!!!!!!!
12-10-2011, 09:22 PM | #106 |
Ok guys a little wkend report--2 cold to finish body work on dash so I took bed apart last week and finish 1 bedside today--Floor will be raised 10 inches-I am not a fan of notch covers so I will raise complete floor --Started on dr. side panel--Reverse mini tub-wood will set on top of angle-Little trick here-always plug weld angle to wall before cutting out below-that way no flexing on the side panel-That's 1x2 tubing between bedside and inner panel-all pieces touching outer bedside are done with 3m panel bond --Tub bolts in-will be 6-7 " wider than pic-That's one half-The tub will have a 1 1/4 flat bar welded all the way around lip INWARD so the bolts will be hidden.............jim
12-10-2011, 09:27 PM | #107 |
More pics-Original look on pass side--how much tub reduced-Floor will look close to this................jim
12-10-2011, 09:31 PM | #108 |
VA72C10
Looking good! Like the inspiration picture
Looking for a 67-72 swb or blazer project in or around VA. |
12-10-2011, 09:42 PM | #109 |
Last truck---something's always give me a burr in my saddle about that pic and I want your opinion--Look at the center 2 boards and tell me it would not look better with a centered bed strip and then run the wide boards all the way out!! I've done the math and it still would look right at the outer edges--I know --I'm anal but it has always bothered me..............jim
12-10-2011, 11:09 PM | #110 |
question for ya...I had previously thought the inner bedsides didn't need to be cut to clear the tires. So I guess my question is why are you doing what you're doing?LOL!
12-10-2011, 11:17 PM | #111 |
Good question-gaining 1 1/2 " towards fender-I didn't have 2 but wheel will sit closer to lip and improve overall look-Don't like look if wheel is inset 2 far-Just a personal choice for me-But there is plenty of room without this mod especially with inboard bridge for bags--Check 1st pic and look how I trimmed the fender lip(roll) about 5/8" all the way around-like late model fenders.........Got 2 finish pass side and then off to blaster.......jim
12-10-2011, 11:19 PM | #112 |
VA72C10
I am totally like you on the width of the boards bothering me... I always planned to install equal sized boards unless I was doing an original restoration (and then it would be painted anyways )
12-10-2011, 11:22 PM | #113 |
Look at that bed pic again-See how I widened tub to overreach the bed strip?? Didn't need that wide but felt it could not fall on strip--changing boards would eliminate this 2!!!..........jim
12-12-2011, 11:07 AM | #114 |
67cheby
looking GREAT !!
12-12-2011, 09:48 PM | #115 |
It's been a while^^^^^ --where U been--Notch cover I suspect?? Love yours but I will leave that labor of love with U--lol-Im not crazy about shorty(depth) bed either but it works for me...let me see the new corner pieces when your done....jim
12-12-2011, 10:50 PM | #116 |
67cheby
You nailed it Been working on hinging it. What a pain
Posted via Mobile Device |
12-16-2011, 01:30 AM | #117 |
Nice work going on.....subscribed!
James '68 Stepside (ground up in progress) My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html '81 SWB "Pap paw" (Driver) The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html Member of www.louisianaclassictruckclub.com https://www.facebook.com/groups/296290610747732/ |
12-18-2011, 08:28 PM | #118 |
Ok ,before I expose these pics need to acknowledge not my original idea--Va72c10 was way ahead of me-also 67Cheby on his notch cover--------well I was between coats of epoxy today and shaZam---this is done without welds-all panel epoxy-Cut new gate(whew!!!) installed 3 by 3/16 backing metal--flush fit script--now all left is lite body work--(actually started this last nite--epoxy needs 4 hrs min to set).............jim
12-18-2011, 08:31 PM | #119 |
Don't know if I have the Kahonnees to cut a real good fender but here is another idea--Looks better in person.............jim
12-18-2011, 08:38 PM | #120 |
One more weekend project done...........I have always had a pet-peave about the area under the bedroll-always rusts-cant paint well............ssssoooooo I shave the inside lip and cap the bottom............makes a nice finished look--This will need a little body work on the roll edge to be perfect---another panel bond project-with minimal welding.............jim
12-18-2011, 09:18 PM | #121 |
C/10 junkie
That's a great idea, always feel rust in this area.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
12-19-2011, 01:27 AM | #122 |
VA72C10
I like the bedside mod. And the gate mod is cool! Much more subtle than my original idea
12-19-2011, 07:12 AM | #123 | |
Village Idiot....
http://www.hubgarage.com/mygarage/n2billet -67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold -71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold |
12-19-2011, 10:41 AM | #124 |
Hey Jim--tailgate looks great. I think the fender would look pretty cool too.
68 Chevy SWB Stepside--under construction--now Fleetside w/18's & 20's--getting ready for 350 TPI motor w/700r4 67 Camaro--17x8's and 19x12's--C5 & Airride Technologies susp. (not finished) 09 Tahoe--lowered w/20's Superformance Cobra--347 stroker w/Weber injection--polished 17's--SOLD 08 Scion Xb w/ground effects and 19's (son's car) |
12-19-2011, 10:44 AM | #125 |
67cheby
i love the tailgate,great work on the bedsides but , think it might be to much on the fenders ?? just my opinion
