Old 12-03-2011, 12:19 AM   #26
Rich 5150 69
Rich 5150 69's Avatar
Re: Got Me some Camel Humps!!
Get em done right they are a good set of heads.....port match, unshroud the exhaust valve wall and match all valve heights......( change out seats and valves that are sunk in heads). Mine are on a 406 smblk.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 12-03-2011, 05:53 PM   #27
JasonWynn88
I think I will go with the 268H cam from comp. will it work fine with stock springs on my camel humps?? Assuming they are stock springs.
JasonWynn88 is offline   Reply With Quote
Old 12-04-2011, 01:18 AM   #28
Captainfab
60-66 Nut
They should work, but it is always recommended to check for coil bind and retainer to valve stem/seal clearence, when upgrading a cam.
Old 12-04-2011, 06:50 AM   #29
Rannos
Rannos's Avatar
I agree with Captain... always double check. As for cam another thought would be the 279 thumper series from comp cams. It is designed to give ya a racier idle and a decent performance boost with out all the hassle of a large cam. Not downing the 268H cam, as it is a fine little cam, but it is 30 year old tech. The newer designed cam profiles can accomplish a lot more with alot less motor. Just a thought.
Rannos is offline   Reply With Quote
Old 01-12-2016, 09:58 PM   #30
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Originally Posted by 1Bad62Pro/Street View Post
Alot of people call them Peanut Heads.
There's no tellin what you would get if you typed that in the search
The famed Camel-Hump/Peanut Heads (or fuelie) heads used until '68 had no accessory bolt-holes and used 1.94 or 2.02 intake valves, depending on application. Most camel-hump heads had the 1.94 intake valves.
Lil' History:
http://www.chevyhiperformance.com/te...#ixzz1fKYqeHQ4
Small Block Chevy Cylinder Head Identification
http://67-72chevytrucks.com/vboard/s...d.php?t=353542
Online engine resources (casting numbers, calculators, etc.)
http://67-72chevytrucks.com/vboard/s...d.php?t=382583
What kind of heads are these on my 283?
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 01-13-2016, 02:07 AM   #31
Captainfab
60-66 Nut
The best thing to do is remove a valve cover and get the casting number. All I can tell you from the pics is that they are a '68 and newer head.
Old 01-13-2016, 09:49 AM   #32
WOLFMANmike
WOLFMANmike's Avatar
If it were me when ever doing a cam swap . I would always buy the cams valve Springs to match said cam as well. It is a peace of mind that is money well invested in your build ... so if you can buy a full cam and lifter set with matching valve Springs. . Also something I have not seen anyone ask you or mention to you is . Do you have power brakes ? Because if you do and you get a cam with a big lope sound that means way less vacuum which means poor brakes if they are power assist. For that you will also want to buy a vacuum can from summit so remember more lope / thump means less ability to stop at lights . Without running a vacuum can .. Happy Truckin
WOLFMANmike is offline   Reply With Quote
Old 01-13-2016, 11:01 AM   #33
jokerz71
jokerz71's Avatar
Those look like #416 305 heads.Best to check casting # to be sure tho.If so,they are the 2nd best 305 head available after the L30/305 Vortec head.Casting #059.
Actually,it appears after looking at both pictures that you have 2 different heads.
jokerz71 is offline   Reply With Quote
Old 01-13-2016, 11:08 AM   #34
jokerz71
jokerz71's Avatar
FWIW,the humps were great heads back in the day & if you're trying be period correct,that's 1 thing,but,if you are looking for performance & efficiency,that's a whole different thing.
A set of L31 Vortec heads,or,any of the similar fastburn heads will be an instant 30 HP over any of the humps.You can make more power with less cam & have much better resistance against detonation.
Unless they have had hardened seats installed,a performance type cam & springs can beat the soft seats out of the head in no time flat.
By the time you have seats installed,install screw in studs & a valve job,you will have a lot of money tied up in a set 50 something year old heads that will be less powerful & efficient.
Old 01-13-2016, 12:39 PM   #35
LostMy65
LostMy65's Avatar
I'm trying to find the other post - I think by you - where you say something about a good newer head that works good on a 283.
Old 01-13-2016, 05:12 PM   #36
LostMy65
LostMy65's Avatar
Found your other post.
Originally Posted by jokerz71 View Post
I agree.That cam is way too big for a 283 unless you are using for strip only.Even then you're gonna need alot of stall & some really low gearing,along with more compressionto get that cam into it'operating range.
A really good head for the 283/307 is the L30/305 Vortec head.Castin g #059. These are a 58cc head & they will flow approx 220 cfm @ .500 lift with 1.84/1.5 valves.The chambers are not as efficient as the L31 heads, but, they work very good on small inch motors.Just like their big brother, the L31, they will need a Vortec specific intake.
EDIT: Sorry.I missed the part where you got it fixed !!! LOL.
Old 01-14-2016, 02:37 PM   #37
68c10owner
68c10owner's Avatar
Did anyone catch the age of the thread?
Anthony
68c10owner is offline   Reply With Quote
Old 01-14-2016, 08:33 PM   #38
WOLFMANmike
the age dont matter to me of this post . because since im still fairly new to the site this post has some good info in it that i my self did not know and now are better equipped when i do my build .. like a for instance the alternator bracket system that does not bolt on the heads . i did not know existed . so im glad that who ever made a comment on this post the site made it look as a new one . or ide never have bumped into this . and got good info
Old 01-14-2016, 09:04 PM   #39
LostMy65
LostMy65's Avatar
I have a lot of old books that still have good information.
An old thread on camel humps or a new thread on camel humps. Same information.
