Old 12-03-2011, 06:09 PM   #1
red69ss
Burnouts are therapeutic
red69ss's Avatar
What's the difference in a pb master cylinder vs. manual ?
like the title says is there a diff. between a power brake mc vs. a manual? This is on a 72 chevy if that makes a difference. I had a guy tell me he took a pb booster and just pulled a manual mc forward and added the booster and it worked with some tweeking to the rod that hooks to the pedal. just wondering if anyone knows of a diff. thanks
1969 CHEVELLE SS
1972 C10 ALMOST DAILY DRIVER
1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE)
1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR)
"My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield
"The difference between genius and stupidity is that genius has its limits." - Einstein
red69ss is offline   Reply With Quote
Old 12-03-2011, 07:05 PM   #2
Ackattack
Ackattack's Avatar
Re: What's the difference in a pb master cylinder vs. manual ?
The bore of the piston are different sizes
Ackattack is offline   Reply With Quote
Old 12-03-2011, 08:25 PM   #3
JimKshortstep4x4
All of the manual master cylinders that I have seen have a very deep tapered hole in them to keep the rod in place. The manual rod has a tapered end to fit the manual master cylinder. I am not sure how you would be able to match the manual rod to the booster or match the booster to the tapered hole in the manual master cylinder.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 12-04-2011, 12:10 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I pulled the master off my blown booster and bolted it directly to the firewall.
i have been told that in these year of trucks they have the same p/n power or manual. I don't know if it is true, however, I have seen plenty of people on here pull the master cylinder off the firewall and slip a booster in there, and roll with it trouble free.
Old 12-04-2011, 12:41 AM   #5
68gmsee
Active Member
68gmsee's Avatar
There's no difference. On my 68 I pulled the master cylinder forward and installed a booster. Several year later the booster went bad and I took it off and rebolted the m.c. back to the original position. I bought a booster last month and again just pulled the m.c. forward and reinstalled the booster.
I did the same on my 69 when I converted it to p. brakes. From what I've noticed the only difference is in the drum/drum vs. disc/drum master cylinders.
68gmsee is offline   Reply With Quote
Old 12-04-2011, 01:43 AM   #6
jocko
jocko's Avatar
Can't speak for all years, but can speak to a 67 drum/drum setup (so my A$$umption is that it's common across all 67-72 drum/drum setups...). Anyhoo, the Non-power drum/drum master was different from the 67 power drum/drum master - the manual had the deep hole in the back of the piston vice the shallow one that fits the booster's intermediate pushrod. Yes, possible to go FROM power to manual with the same master - the opposite is not true in a bolt-on fashion - will take some modificaiton of the interface/intermediate push rod between the booster and master.
Old 12-04-2011, 01:44 AM   #7
screamin_c10
I dun gradjiated collij!!!
screamin_c10's Avatar
Originally Posted by 68gmsee View Post
There's no difference. On my 68 I pulled the master cylinder forward and installed a booster.....
I did exactly the same thing, just needed to lengthen the warning light wire a bit....
screamin_c10 is offline   Reply With Quote
Old 12-04-2011, 08:59 AM   #8
red69ss
red69ss's Avatar
wow thanks for all the great replies! it sounds like it is deffinently a possibility so I'm going to try it. it will be a couple of weeks before I can try it I have to get the truck home first , but I'll let yall know my experience with it . thanks
1969 CHEVELLE SS
Old 12-04-2011, 01:57 PM   #9
68gmsee
Active Member
68gmsee's Avatar
... Yes, possible to go FROM power to manual with the same master - the opposite is not true in a bolt-on fashion - will take some modificaiton of the interface/intermediate push rod between the booster and master.
Yeah, some modifications are required. I did have to adjust the push rod on the booster to m.c. out some, change out the brake pedal pushrod and adjust the brake light switch.
Mine was a little tight but just long enough.
Old 12-05-2011, 03:53 AM   #10
dmack91
dmack91's Avatar
Mine bolted straight in with no adjustments that I recall. Works great. 68 Drum/drum.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 12-05-2011, 04:30 AM   #11
SS Tim
SS Tim's Avatar
Its worth remembering that Power Brakes were also offered as a dealer installed accessory. My '69 list shows two kits, one for C,K10 and another for C20-30,K20.
SS Tim is offline   Reply With Quote
Old 12-05-2011, 11:30 PM   #12
609thomasm
609thomasm's Avatar
Some manual brake master cylinders have a residual pressure check valve. This should not be used with disc brakes. The valve is behind the brass seat that the line seals against in the port. I had a 67 camaro in the late 80's that I installed disc on the front and removed the valve in the port for the front. I have heard that these were stop being used sometime in the early 70's.
609thomasm is offline   Reply With Quote
