Old 12-04-2011, 07:22 PM   #1
rockachevy
rockachevy's Avatar
have any body done this
has anybody here switched a IFS truck to solid axial truck, i wanted to know how hard it was and about how much did this project cost because i was thinking about doing this to my truck.
rockachevy is offline   Reply With Quote
Old 12-04-2011, 08:32 PM   #2
Altec
Getcha Pull
Altec's Avatar
Re: have any body done this
A popular conversion on Pirate4x4. Search on there.
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Altec is offline   Reply With Quote
Old 12-04-2011, 09:56 PM   #3
rayfinseats
I have both trucks and IFS rides way better. I just thought I'd mention that. You can do anything if you have enough time and money.
rayfinseats is offline   Reply With Quote
Old 12-04-2011, 10:04 PM   #4
Psycho71
Psycho71's Avatar
I saw two guys do it on a truck show on TV a while back. It only took them about 30 minutes to do it.
Seriously though. It looked like they had a kit that pretty much made it a bolt-in job once all the IFS stuff was removed. If I remember correctly, they did it to a full size blazer or something similar. I only halfway paid attention to it though. Positive it was a GM product though.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 12-04-2011, 10:24 PM   #5
Altec
Getcha Pull
Altec's Avatar
Ride quality is set by how your holding the vehicle up. Not what the tires bolt to. Leaf spring ride is all about length of packs, what makes up the packs, and proper spring rates for vehicle weight. Along with shackle angle, and proper shock placement. Linked suspensions are a bit more in depth.
Factory setups are always made practical, never perfect.
A solid axle held up by some half ton 52" rear springs, with a slightly exaggerated shackle angle, and close-to-vertical mounted shocks will ride like a caddy.
Pretty much the entire conversion can be done off the shelf. For both leaf springs, and linked suspensions.
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Old 12-05-2011, 07:23 AM   #6
http://offroaddesign.com/catalog/88-...Conversion.htm
Old 12-06-2011, 12:27 AM   #7
rayfinseats
"A solid axle held up by some half ton 52" rear springs, with a slightly exaggerated shackle angle, and close-to-vertical mounted shocks will ride like a caddy."
I have heard that too. Why didn't Chevy do it that way to begin with? So much for engineers.
Old 12-06-2011, 07:54 AM   #8
Cuz back then girls didn't drive trucks . Trucks were "engineered" for work. Working a truck means hauling weight. Trucks weren't engineered to ride empty. These trucks were engineered to last and they are doing that very well.
