Old 12-04-2011, 09:27 PM   #51
justcuz
justcuz's Avatar
Re: 66 GMC 4x4 Sub. Just got it!
Originally Posted by padresag View Post
some did come with a 3 speed though
ron
Yes that is true. I had a buddy who bought a 65 3/4 ton with a 292, 3 on the tree 4x4. We swapped it out to a 4 spd and boy what a difference in the crawl ratio.
justcuz is offline   Reply With Quote
Old 12-04-2011, 09:55 PM   #52
dugvera@gmail.com
dugvera@gmail.com's Avatar
I had a 72 blazer that had a stick in it. It was the one with the granny low gear and in 4 low you could let the clutch out without even touching the gas.
dugvera@gmail.com is offline   Reply With Quote
Old 12-05-2011, 01:45 AM   #53
Captainfab
60-66 Nut
If you switch to a disc brake front differential, you will at least have to change your master cylinder to a dual reservior disc/drum master, along with the proportioning valve. This can be done as manual brakes or power brakes.
More than likely your differentials have 3.73 gears. But as said above, back then you could order most anything. When searching for a donor for the front differential, if you find a '76-'87 K5 or K10, the rear differential will have the wider 2-1/2" brakes. That would be worth purchasing for the brake upgrade IMO.
Originally Posted by dugvera@gmail.com View Post
Sounds good! How about the breaks? Should I do all that at the same time too, or will it be okay to run the later disk breaks on my manual break system for a while?
What gears did these trucks come with? Mine was a stick shift truck. It seems like they must be low to me. It has no problems getting up to speed. But then again my daily draiver is on 35swith no geand a 3 speed auto so maybe I'm a bit used to a more sluggash start from that. Thanks again guys.
Old 12-05-2011, 02:09 AM   #54
dugvera@gmail.com
Very good. I think I have what I need to know now. Ill send you a message when I need parts. Thanks.
Doug
Doug
66 4x4 GMC Suburban
76 4x4 Chevy Shortbed
Old 12-05-2011, 10:03 AM   #55
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Ron, I took math in school as well, but thank you for pointing that out. What would you like to argue about now? lol
Ladies, Ladies...Please ... LOL !!
Nice Burban, looks to be really solid !!
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 12-05-2011, 08:45 PM   #56
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
He started it! I'm gonna tell Mom! LMAO.
Old 12-12-2011, 09:07 PM   #57
dugvera@gmail.com
Name:  door panel.jpg
I was playing around with some colors. I like these. I know the pic isnt that good.
Doug
66 4x4 GMC Suburban
Old 12-24-2011, 02:16 AM   #58
dugvera@gmail.com
Got some wheels on the burb.
Doug
66 4x4 GMC Suburban
Old 12-24-2011, 10:38 AM   #59
'63GENIII
'63GENIII's Avatar
Dude you aren't wasting any time! Two tone? I think that looks awesome. The wheels don't look too shabby either. Nice work.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 12-24-2011, 12:39 PM   #60
dugvera@gmail.com
I only painted one door to see if i was going to like the colors. I also put a new shifter in, new side mirrors, backup light lenses, rebuilt the heater lever system on the dash, and put a stereo in. I was kinda bummed the dash was cut up for a stereo before i got it but oh well, made it easy to deal with a new one. Now that I know I like the paint Id like to do the whole interior so i can soundproof and carpet it
Doug
66 4x4 GMC Suburban
Old 01-14-2012, 08:58 PM   #61
dugvera@gmail.com
Today I pulled the distributor out of the burb and put a different one in. I replaced the one in my '76 about a year ago with an msd hei unit. So, I used the perfectly good one I pulled out to replace the suspect one in the burb. It had a dead miss at start up but would go away after it warmed up a bit. I wasn't sure if it was a carb,,, ignition,,,, lifter,,,, issue but beings the dist. swap wouldnt cost a dime Id start there. Cured the problem and can tell a huge difference in performance. And it took like 10 minutes! Now the wife claims the saved $ should go should go into her clothes shopping fund.
Doug
66 4x4 GMC Suburban
Old 01-15-2012, 12:52 AM   #62
Captainfab
60-66 Nut
Ah, now you see where you went wrong? You should have taken the MSD out of your '76 to try it out. Then you would have to say to your wife 'Well honey it looks like I will be needing to buy another distributor to put in the '76 now"
Old 01-15-2012, 12:56 AM   #63
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
Sweet rig!
1978 C3500 Crewcab (Project)
1979 C2500 Crewcab (Driver/project)
1988 R2500 Crewcab (Driver)
1988 V3500 Crewcab
1988 R2500 Crewcab (Mint, Ex Fire Dept)
1968 Chev Suburban (4x4 conversion) LINK
1970 Chev C20 Suburban (driver/cruiser)LINK
2005 Impala (Incognito vehicle)
2004 Yukon XL Denali (Kid hauler)
1947 Case tractor
Facebook Page(1000's of pictures of GM cars and trucks organized into albums)
YouTube Channel
Mr Pops is offline   Reply With Quote
Old 01-15-2012, 01:10 AM   #64
dugvera@gmail.com
You my friend are a genius! Hahaha! Seems I might need to pull the new dougs headers off the '76 and check for clearance to see if I can get the same ones. Once they are bolted up may as well just leave them and get another set. Shoot I can probably pull the front axle and steering box to test out your pewer box bracket! Hahaha!
Doug
66 4x4 GMC Suburban
Old 01-15-2012, 02:11 AM   #65
burbluv
burbluv's Avatar
Looking great! Do you mind sharing the specific info on your interior colors?
burbluv is offline   Reply With Quote
Old 01-15-2012, 02:19 AM   #66
dugvera@gmail.com
Yeah, not sure what the color name is for sure but it was all one solid color kind of an olive green. Everything, seats, dash, floor, all of it.
Doug
66 4x4 GMC Suburban
Old 01-15-2012, 01:59 PM   #67
dugvera@gmail.com
Got some new turn signals.
Doug
66 4x4 GMC Suburban
Old 06-24-2012, 02:52 AM   #68
MikeS.
MikeS.'s Avatar
Hey man, my new burb is at the truck terminal in VA. About 50 miles away. I should be able to pick it up Monday. I bought a set of axles from an 87 Burb to give me front disk and the ability to raise it of I decide to.
You really inspired me to get 1 of these, so thanks! I guess
Mike
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 07-01-2012, 01:54 AM   #69
piratexpress1369a
piratexpress1369a's Avatar
any updates
My 63 GMC Panel Slow Build
http://67-72chevytrucks.com/vboard/s...=1#post5457281
63
piratexpress1369a is offline   Reply With Quote
Old 07-01-2012, 01:26 PM   #70
ole dollor
ole dollor's Avatar
i like it alot.....don't touch it....leave it just like it is.....great truck....
ole dollor is offline   Reply With Quote
