Old 12-04-2011, 09:29 PM   #1
ashtray455
need some tips on putn a camaro subframe on 57 chevy pickup
getn ready to put an 79z28 subframe under my 57 3100 need some tips maybe some measurements where i should cut the frame anything well help thanks
ashtray455 is offline   Reply With Quote
Old 12-04-2011, 11:02 PM   #2
Maximus
Maximus's Avatar
Re: need some tips on putn a camaro subframe on 57 chevy pickup
For all of the measurements I bought the DVD from No Limit engineering. They are a premium sponsor here too so can probably help you better if u buy the DVD and still have questions... Best money I have spent yet on my build.
You can also run the weary feature on subframe swap, theres like a dozen subframe threads
Good luck! The conversion is a rewarding one!
Maximus is offline   Reply With Quote
Old 12-04-2011, 11:15 PM   #3
Maximus
Maximus's Avatar
Hey just stumbled across this build thread, check out page 1, he shows some good photos/measurements
http://67-72chevytrucks.com/vboard/s...d.php?t=220256
Old 12-05-2011, 12:16 AM   #4
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
Here is something directly for the No Limit folks, hopefully this will help.
http://67-72chevytrucks.com/vboard/s...d.php?t=440771
Tri5
1955 Chevy Stepside/LS1 drive train
http://67-72chevytrucks.com/vboard/s...d.php?t=371513
Tri5Nerd is offline   Reply With Quote
Old 12-05-2011, 02:16 PM   #5
azsnow
azsnow's Avatar
I did a subfram swap on a 57 a couple of years ago and I almost went the same way as Nolimit, but for my taste, it sits way to low when done. http://www.jalopyjournal.com/forum/s...amaro+subframe
I did the swap by follwing this post on HAMB, and it was awesome when I was done!
azsnow is offline   Reply With Quote
Old 12-05-2011, 06:22 PM   #6
Indian113
Indian113's Avatar
Anybody seen these before?
These are a 57 with a camaro clip!!!
Indian113 is offline   Reply With Quote
Old 12-05-2011, 07:18 PM   #7
Maximus
Maximus's Avatar
hmm Im a little confused by this... the way the HAMB link installed the subframe, actually makes the vehicle sit LOWER (if i'm not mistaken) than the No-limit install. the higher the subframe sits above the frame, the lower the truck will sit.
when I did the No-limit install my subframe was at the same level as the original frame, the method you mention, and also similarly shown by the post below yours, have the subframe sitting above the original frame, thus the wheels will be higher in the wheel well, dropping the truck front end.
looks nice! just that method sits too low for me
Old 12-05-2011, 07:24 PM   #8
Kabwe
Certified Car Nut
Kabwe's Avatar
Maximus,
You are correct it does make the truck lower (installing the clip under the frame) than the no limit way (even with the frame rails) because it does not have the kick up like when you install the clip with the unibody supports under the frame. I don't like getting in debates so I did not say anything, but since you said it first I thought I'd chime in.lol
By the way there is no such thing as too low.lol
Kabwe is offline   Reply With Quote
Old 12-05-2011, 08:37 PM   #9
Indian113
Indian113's Avatar
Just run TALLER TIRES!!!!!!
Old 12-05-2011, 09:12 PM   #10
ashtray455
thanks everybody ill check it out thanks
Old 12-05-2011, 09:57 PM   #11
azsnow
azsnow's Avatar
I stand corrected on the height issue after taking a peek at both methods.
Old 12-05-2011, 11:24 PM   #12
azsnow
azsnow's Avatar
But for some reason my truck didn't seem to sit as low in the front as the no limit way. These trucks look good with a bit of a lowered stance, but IMO there is a point when it looks retarded.
Old 12-06-2011, 10:51 AM   #13
Kabwe
Certified Car Nut
Kabwe's Avatar
Yeah, yeah and its people that feel the same about a truck that sits too high, so to each his own. When you say things like that it is insulting to a lot of people. If you don't like it simply don't do it. Beauty is in the eye of the beholder. Some guys like big women some like em small skinny legs and all.lol
But nobody is wrong about what they like.
Old 12-06-2011, 11:03 AM   #14
LDO
LDO's Avatar
Originally Posted by Kabwe View Post
Yeah, yeah and its people the feel the same about a truck that sits too high, so to each his own. When you say things like that it insults a lot of people. If you don't like it simply don't do it. Beauty is in the eye of the beholder. Some guys like big women some like em small skinny legs and all.lol
But nobody is wrong for what they like.
I like a skinny legged woman that sits low!
LDO is offline   Reply With Quote
Old 12-06-2011, 11:28 AM   #15
meter swinger
meter swinger's Avatar
never get tired of looking at these.
meter swinger is offline   Reply With Quote
Old 12-06-2011, 12:43 PM   #16
Kabwe
Certified Car Nut
Kabwe's Avatar
Originally Posted by ldo View Post
i like a skinny legged woman that sits low!
lol.
Old 12-06-2011, 01:51 PM   #17
mknittle
mknittle's Avatar
Maximus,
Kabwe, my brother in-law has a disclaimer for the debaters.it goes something like this:
My opinion is just that.It is NOT open for debate.It is just my opinion!
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 12-06-2011, 04:31 PM   #18
azsnow
azsnow's Avatar
Yeah, yeah and its people that feel the same about a truck that sits too high, so to each his own. When you say things like that it insults a lot of people. If you don't like it simply don't do it. Beauty is in the eye of the beholder. Some guys like big women some like em small skinny legs and all.lol
Hence the reason I said IMO (In MY Opinion)
If you get offended that easy, perhaps you should be on the Discovery web site tonight voting for Paul Jr because it hurt your feelings that Jessie James cheated on Sandra.
Old 12-06-2011, 05:35 PM   #19
Maximus
Maximus's Avatar
I'm SURE Kabwe was not offended, he is just lookin out for others...
Anyways, back on topic...
Ashtray455, Which way are ya going with your front end conversion???
Old 12-06-2011, 05:48 PM   #20
55metalmonkey
looks familure
55metalmonkey is offline   Reply With Quote
Old 12-06-2011, 06:35 PM   #21
Speedbumpauto
Speedbumpauto's Avatar
It DID hurt my feelings. I gave him credit for being marginally smarter than that and it hurts when I'm wronge!
Speedbumpauto is offline   Reply With Quote
Old 12-06-2011, 07:08 PM   #22
Kabwe
Certified Car Nut
Kabwe's Avatar
Nope I'm not offended at all. There are a lot of people here that work very hard on their rides and like them low and even slammed to the ground on airbags. Those same people have a lot of knowledge, and comb this forum to try and help people. You've just called their rides "retarded looking". If you don't see that as a insult then that tells me something about you and there is no need to go back and forth on this.
The gentelman (original poster) asked for the facts. The fact is installing the clip with the unibody supports under the frame will give you a lower stance (with stock components) than if you installed it even with the frame rails. Its up to the original poster to decide what he is going to do now that he is armed with the information.
You got that right. I'm a car nut and I like everything from stock to way out customs. I know how hard this stuff is to do on your own in your garage, people work very hard to build something they like and I think its very insulting to make a statement like "retarding looking" when a guy bust his a$$ to build his truck.
Old 12-06-2011, 07:53 PM   #23
ashtray455
maxium havnt decided yet was lookn at one guys i like the way his had turned out where he slice a section out of thframe then sliced clip an welded it in , but still reserching it
Old 12-06-2011, 08:01 PM   #24
Kabwe
Certified Car Nut
Kabwe's Avatar
I think you are talking about the "no limit way" they sale a instruction dvd for 36.00 if you need it. Heres a link for you http://www.nolimitparts.com/prodinfo.asp?number=D-101
Old 12-06-2011, 08:06 PM   #25
ashtray455
thanks kabwe man like ur truck lookn good
