12-04-2011, 09:41 PM | #1 |
Picture of Jack Handle and Tire Tool on fender well 81-78
Like the Subject says. Does anyone have a picture of how this is supposed to bolt in? Thanks in advance.
85 Silverado SWB |
12-05-2011, 07:34 AM | #2 |
Re: Picture of Jack Handle and Tire Tool on fender well 81-78
On my 83 C20:
12-05-2011, 09:30 AM | #3 |
Mine has the Bottle on the Drivers Fender and the Handle and Tire Iron on the Pass. Like your setup beter though. Keep it all together.
85 Silverado SWB |
12-05-2011, 10:30 AM | #4 |
Big Gulps Huh? Whelp...
I'll post a photo of my driver side mount '87 when I get home...
"The Ghost II" - 1987 V30 CC, 14-BFF (2nd Design Heavy Ribbed HD) SRW Conversion, 454/4L80E/205, 6" Springs, 35" Toyo MT's on 17" Classic II's, Full Audio System, Lot of Other Goodies!
12-05-2011, 11:12 AM | #5 |
That's the way my '86 is too. Reason being, the coolant overflow is on the pass side.
1st - '68 long bed 2nd - '81 SWB Now - '86 SWB, Edelbrock 1406/stock 350/700r4 |
12-05-2011, 04:26 PM | #6 |
Coolant overflow is on the passenger side on my 83 also, but the jack and handle still fit there - the long jack handle goes through a hole in the core support. It does not look very well designed but that is the installation instruction on the decal under the jack on the inner fender.
12-05-2011, 09:02 PM | #7 |
can someone post how the tools arrange on an 87 on the passenger side? my jack is in place on the drivers side but all the tools that are supposed to go on the passenger side as behind my seat and have been since the 80s!
12-06-2011, 09:10 AM | #8 |
Did 87 change from 83? If not, then my pics show the tools and jack in place on the passenger inner fender. If you can find a pic of the fender decal for an 87, then that would show the proper location of the jack and tools. I think LMC sells the decals, at least some of them, so you might check their catalog, or Classic Parts for an idea.
12-06-2011, 10:54 AM | #9 |
78K & 79C Jimmys
78 jimmy blue
and 88 burb gold
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
12-06-2011, 04:50 PM | #10 |
From 86 Suburban
12-14-2015, 11:59 AM | #11 |
How about a picture of a 77 jack set-up, pass side? Thanks..
Philippians 4:8, Victory through pure thoughts. |
12-14-2015, 12:13 PM | #12 |
As I recall, my 77 had the same set up as the picture of my 83 in the second post above. My 83 picture shows a 3/4 ton jack, but I have since replaced it with a 1/2 ton jack because the 3/4 ton jack would not work.
12-14-2015, 04:41 PM | #13 |
Ok, that'll be fine then, tha
02-02-2016, 08:37 AM | #14 |
I'd like to buy a set if anyone knows of one. 1978 GMC
02-02-2016, 03:09 PM | #15 |
I would check the pick and pull, but they usually remove the jack before the vehicle goes out on the lot to prevent people from jacking up the vehicles. Ebay often has used jacks, but make sure that the one you get actually works.
02-03-2016, 10:20 AM | #16 |
I have tried a jeep jack and a ford jack, both look very similar, but no way will fit properly. I have tried placing the jack many different ways. I do have the correct mounting brackets, front and back of wheel well. And...my jack instructions sticker is still in good shape, so I was using that to make sure I had proper placement. Guess i'll have to get a 70's chevy truck jack from ebay or something. Thanks all for the pics and replys.
02-03-2016, 11:48 AM | #17 |
Great timing on this, I'm at the point of reinstalling these items on my truck. ,I failed to tag the bolts that hold the tools down. There different lengths. Thanks for the photo's.
Ken
1985 IROC Z28 190HP TPI 305,700r4,T-tops,rear trac lock, Black on lite gray, 16in Z28 wheels 2007 Lexus ES350 (wifes) 1984 CJ7 with 1995 HO4.0L MPI, 2 1/2 OME YJ Lift “There is no limit to the amount of good you can do if you don't care who gets the credit.” ― Ronald Reagan |
